Author Topic: GroovyMAME 0.147u3 SwitchRes v0.014 problems with lots of games  (Read 3956 times)
yakk11
  • Last login:April 23, 2025, 11:52:20 pm
« on: January 27, 2013, 06:29:26 pm »
I have compiled this with cave sh3 games enabled.  Some games work, some don't.  It seems that almost ALL vertical games no longer work (pacman, galaga, etc), mk, mk2, mk3, wargods, golden tee games, etc.  I had groovymame 146 was working perfectly.  I'm assuming its due to all of the great new changes you have implemented.  When i try and create a log file, this error pops up in the command window before creating the txt file:
Unable to create the Direct3D device (8876086C)
Unable to initialize Direct3D.
  000000000021E730: 00000000016D3087 (not found)
  000000000021EC00: 00000000022E2DDE (not found)
  000000000021ED60: 00000000016D9B44 (not found)
  000000000021EF20: 00000000016D7962 (not found)
  000000000021F140: 00000000016D419A (not found)
  000000000021F450: 0000000001DE369C (not found)
  000000000021F630: 0000000001DE48BD (not found)
  000000000022F3F0: 0000000001D0C5B7 (not found)
  000000000022F8D0: 0000000001FECDCE (not found)
  000000000022FE30: 00000000016D6096 (not found)
  000000000022FE80: 00000000022BD38C (not found)
  000000000022FF40: 00000000004013F0 (not found)
  000000000022FF70: 00000000004014F8 (not found)
  000000000022FFA0: 0000000077D596AC (BaseProcessStart+0x002c)
Unable to complete window creation
Here are my mame.ini and vmmaker.ini and various log files in a zip file.  Any help?
« Last Edit: January 27, 2013, 06:32:24 pm by yakk11 »
Calamity
  • Moderator
  • Last login:Today at 03:57:20 pm
  • Quote me with care
Re: GroovyMAME 0.147u3 SwitchRes v0.014 problems with lots of games
« Reply #1 on: January 28, 2013, 05:27:40 am »
First question: have you tried the 'official' GroovyMAME builds? Same problem?
Steps to create a log:
yakk11
« Reply #2 on: January 28, 2013, 09:30:36 am »
I sure did.  That's actually the last thing that i tried.  Does my vmmaker file look ok?
Calamity
  • Moderator
« Reply #3 on: January 28, 2013, 10:11:58 am »
Yes, everything looks right. The problem seems to be related with magic resolutions. Try using ModeTableMethodXML 1 in vmmaker.ini, just for testing.
yakk11
« Reply #4 on: January 28, 2013, 07:07:56 pm »
changing that seems to have fixed most of my problems.  I am running hyperspin as my front end, so i had to change the modeline value to 100.  Everything seems ok except NFL Blitz and the psx system 11/12 games are running in a tiny screen.  And Tekken 3 seems to run a lot slower (i'm running with an intel core i5 3570k).  Thank you so much for your continued support!
yakk11
« Reply #5 on: January 29, 2013, 07:06:50 pm »
Any help as to why Tekken 3 is running so slow and running at about 13-14" on my 29" monitor.  Any settings in mame.ini that i need to change?
