Author Topic: Identifying power plug on Electrohome G07-CBO  (Read 7178 times)
Entropy42
  • Last login:August 09, 2023, 11:27:44 pm
  • Not a llama.
« on: January 06, 2013, 01:05:36 pm »
I have an Arkanoid Cocktail that I am trying to fix up, and this 2 wire cable comes off of the monitor and goes into a plug that does not mate with anything in the cabinet.  So I have no idea what the top and bottom pins are expecting.  Really don't want to wire it up backwards and toast the monitor.
The first picture below is just a close up of the cable coming out of the monitor, and the 2nd pic is a shot of the end of the plug.  Given that just about every connector in this cab has been hacked off and electrical taped back together, I don't have too much faith that the plug is any sort of standard.
I'm assuming one of these 2 wires is hot, and the other is neutral.  Can anyone give me some guidance as to which is which?
ed12
Re: Identifying power plug on Electrohome G07-CBO
« Reply #1 on: January 06, 2013, 01:43:04 pm »
the 2 wire's in your pic are the power plug
now rember it is a hot chassic..which mean's u use an isolation transformer
when using it and servicing it
they were not really :power-phased: ie white/black
ed
Entropy42
  • Not a llama.
« Reply #2 on: January 07, 2013, 09:59:39 am »
ed
Are you saying that it doesn't matter which side of the AC goes into that plug?  Is in, its impossible for me to plug it in "backwards"?
« Reply #3 on: January 07, 2013, 01:42:51 pm »
ed
no dont do that. I'll look at my Galaga when I get home. I thought I had a pic on my phone but I cant find it. Just wait a couple hours.
ed12
« Reply #4 on: January 07, 2013, 03:00:18 pm »
hi
this simple reason they are both black tell's u they are not phased
but if u find 1 with a white and black wire then that 1 is phased
follow it.
if u are that concered i will look up g07/g08 for u
or if it really matter's u could pm rickn he was the eng on that team
ed
« Reply #5 on: January 07, 2013, 08:24:04 pm »
the circle plug is the negative. the "half moon" is the positive. I followed the wires all the way down to the iso xformer just to be sure.
Entropy42
  • Not a llama.
« Reply #6 on: January 07, 2013, 10:36:39 pm »
So positive and negative being black and white, respectively.  Correct?
Thanks for looking it up for me.
« Reply #7 on: January 08, 2013, 08:12:22 am »
I cant go by colors, someone may have wired it up with what ever colors they had. just follow the leads on the ISO transformer. If in doubt post a picture of the leads of your isolation transformer and I'll tell you which one.
Entropy42
  • Not a llama.
« Reply #8 on: January 08, 2013, 11:43:47 am »
Thanks. There is a Williams Defender iso transformer in my cab, that previously powered the monitor.  The schematic for it is the attachment below.  From what I can tell, the 2 AC lines intended for the monitor are the 2 Violet/Yellow wires coming off of the transformer at pin 9 and 10.  I can't tell which of them would be positive or negative though.  If I had to guess, I would say 9 is positive.
« Last Edit: January 08, 2013, 11:59:05 am by Entropy42 »
« Reply #9 on: January 08, 2013, 11:56:12 am »
I'll take a picture of mine when I get home, best I can do
paigeoliver
  • Awesome face!
« Reply #10 on: January 08, 2013, 04:07:31 pm »
It will still work if you wire it up backwards, it won't toast, however there can be safety concerns. http://www.phillylicensedelectrician.com/polarity-matters-in-ac-wiring/
Although the isolation transformer completely removes continuity of the monitor's AC power from the mains, so I am not sure if it actually does matter.
« Reply #11 on: January 08, 2013, 07:00:47 pm »
if they wired it right, yeah, thems the colors on mine. I cant seem to take a good pic.
Entropy42
  • Not a llama.
« Reply #12 on: January 09, 2013, 03:14:58 pm »
Thanks for all the help everyone.  Even if it turns out it didn't matter, I still appreciate all the explanations and the piece of mind.
« Reply #13 on: January 10, 2013, 02:34:17 pm »
maybe this helps:
The black wire on the ISO goes up to the half moon connector, and the white goes up to the circle side.
