December 12, 2025, 07:39:34 am
Would this work on a 1680x1050 resolution monitor? Thanks for any feedback...i have a 22 inch 16:10 monitor.
New to this sort of thing. I've purchased an SLG, but I want to use it with a 1600x1200 monitor (Syncmaster 214T). Will it operate at that resolution...
Quote from: gnomenthusiast on August 27, 2015, 06:50:53 amNew to this sort of thing. I've purchased an SLG, but I want to use it with a 1600x1200 monitor (Syncmaster 214T). Will it operate at that resolution...Same here, I have a Dell 2001FP and I was wondering if I could use this too. Thanks!
Hey Joe, you are correct that if MAME sets the VGA resolution to 640x480 (or 1024x768), then the mini SLG will add scanlines to the image. If you have a MAME front-end and don't want scanlines for those screens, just run the front-end at a higher resolution than 1024x768.
Hi !
this thing is awesome!! I have been converting a space invaders cocktail to a mame machine and been pulling my hair out trying to get it looking good with mame effects but that allways messed up something else (audio or frame drops) set it to 640x480@60 not effects and I cant ask for anything more. thanks
The scanlines are going the wrong direction, instead of vertical, they should be horizontal.
The scanlines are going the wrong direction, instead of vertical, they should be horizontal.later-1
