Hi Guys,
I would like to share with you some issues I have with a new CRT monitor installed in a MameCab machine.
This monitor is a M Monitor 25 inches Dual Autosync 15-25khz. It was manufactured by Electronic Systems in Italy around 2005. This monitor is a clone of the old
Hantarex Polo monitor line and was pattented to Electronic System after Hantarex stopped activities. It was still new in box when I got it from an unsold stock.
I investigated and gathered some more information over the net....I am almost 100% sure this monitor has been licensed by Hantarex when they stopped CRT production and has the same chassis and characteristics as the old POLO2 15/25Khz...it's basically the same monitor.
I am using it horizontaly in a mamecab machine with AVGA9250 and Groovymame under XP32. When I fired it up I was glad to see a bright image and very nice colors (there is no video amp connected to the VGA inputs but I assume it's fine as the image is very bright) but started also to notice some hickups...
The most annoying for me is the V-size image which I can't get till the edge of the screen. I have turned the V pot to the far-end position available but there is still almost 10% of the screen still black on top and bottom. Note that I don't have this issue when a vertical game is launched in groovymame and all the available height is used.
I have also noticed some gray shading stripes on the background of the image on the left and right side. It is clearly visible with light colored backgrounds. The pictures I enclosed are self explanatory. The arcade monitor test reveals also some geometry issues which may explain this grey shading.
The image is also not perfectly horizontal but is slightly rotated clockwise. Playing with all the available pots (pincushion, trapezoid, cont, brigh, v-size etc) will not solve any of those issues...
My question is to know what's wrong with the monitor and what action can be taken to fix this??
PS : for a better view of the grey shading do not look at the pictures to close...
PSS : I have enclosed another picture with the mediaplayer background to better show you those grey bands. A big one on the left side over 1/3 of the screen area and a small one on the right side.
Update : I am trying to isolate the problem so I tested with another videocard and same issue on screen. The problem is not coming from the video signal at least.
