Author Topic: help identifying monitor  (Read 2070 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: December 04, 2012, 08:59:18 pm »
does anyone know what model is my monitor its in a war gods cabinet.
grantspain
Re: help identifying monitor
« Reply #1 on: December 05, 2012, 02:15:17 am »
looks to me like a wells gardner U5000 25"
adidas1984x
« Reply #2 on: December 05, 2012, 07:31:10 am »
can I put a standard res chassis on it , or will it mess up the monitor. or can I use a jpac on a medium res monitor?
grantspain
« Reply #3 on: December 05, 2012, 11:40:13 am »
yeah there is a jumper plug at the front of the chassis,has loads of black wires-just plug it to the header marked 15k
adidas1984x
« Reply #4 on: December 05, 2012, 01:47:14 pm »
are we talking about the new weiya chassis ?
adidas1984x
« Reply #5 on: December 05, 2012, 01:59:55 pm »
Im wanting to use if possible then new universal chassis on the medium tube if you think it will work . The chassis is standard res but the tube well has a u5000 chassis and is for the game war gods which uses med resolution.
grantspain
« Reply #6 on: December 05, 2012, 02:09:19 pm »
i am confused,the monitor chassis you have at present is a u5000 wells gardner
it is manually switched from 15k to 24k by use of the jumper plug i described
in other words you can run 15khz or 24khz games on this chassis by moving the frequency jumper
adidas1984x
« Reply #7 on: December 05, 2012, 02:27:17 pm »
Correct that is my u5000 tha something is wrong with at times the image goes to just a bright colorful 1 line across the center screen, so I was wondering could i use this new universal chassis that is standard res on this monitor tube and it work properly I know that this tube has i think 1 extra pin on the tube neck
grantspain
« Reply #8 on: December 05, 2012, 06:12:54 pm »
u5000 yoke is almost same as hantarex polo so i would expect any cga low impedence chassis of 25" to work
your line is vertical collapse which is most likely bad solder or capacitor-if it were the ic then it would fail constantly
MonMotha
« Reply #9 on: December 05, 2012, 06:23:22 pm »
Wells monitors are famous for bad solder joints.  Just touch up everything in the vertical section and you've probably got yourself a working board for essentially free rather than having to buy a new universal boardset.  Then again, the U5000 is somewhat problem prone.  Up to you...
adidas1984x
« Reply #10 on: December 06, 2012, 02:48:50 pm »
Well I have a spare chassis its the one in the video on the ground, I just didint want to hook it up and screw up the tube if that standard chassis would not work on that med res tube
grantspain
« Reply #11 on: December 06, 2012, 05:38:11 pm »
what the wei ya model number plus on the label of the wei ya chassis it should have the inductance and impedence specs
adidas1984x
grantspain
« Reply #13 on: December 07, 2012, 02:48:15 pm »
yoke specs for u5000 are
vertical 5 ohms
horizontal 1.8 ohms
according to that chassis info it will not work with your yoke
thing is most low impedence cga chassis tend to work fine on other tube/yoke combinations
