Author Topic: ideal computer for mame?  (Read 1910 times)
GodSin
  • Last login:September 30, 2014, 02:58:11 pm
« on: October 31, 2003, 05:24:55 am »
ok since my PII 450 runs mame like crap  :-\
what would be the ideal mame computer?
that would be able to play all current games at best speeds?
cpu / video card / sound card  and what not
Thanks again in advance ...
paigeoliver
  • Awesome face!
Re:ideal computer for mame?
« Reply #1 on: October 31, 2003, 05:38:28 am »
Try reading around a bit more. This gets asked every single day.
The quick answer is that your computer can already run 95+ percent of the games in Mame, and there will never be a computer that can run them all because they keep adding new ones that won't run full speed on current hardware.
The money you would spend buying a new computer in a feeble attempt to run EVERYTHING would be better spent elsewhere.
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
« Reply #2 on: October 31, 2003, 10:41:09 am »
If you love the old classics, you can play several great ones on a Pentium 100mHz using Sparcade.  A 400mHz can play many games in DOS mode that it may struggle with in Windows.  Also, try using an older version of MAME such as ver. 036.  I can play Outrun on a 300mHz in DOS mode, so I know your 400mHz can do more than you think it can.
Darryl
Jetto Funk
  • Last login:April 09, 2013, 03:10:28 pm
  • Moo
« Reply #3 on: October 31, 2003, 07:40:47 pm »
My Amd Athlon XP 1600 with 512 megs of ram doesn't even run all the games at full speed.
DAmnb
  • Last login:July 28, 2011, 03:35:40 pm
  • R-Type for president!
    • TheGameCollector
« Reply #4 on: November 01, 2003, 09:11:31 am »
My P3 733 with 256mb ram runs almost all games and the games that doesnt run perfectly doesnt run perfectly on my P4-1800 either so  ::)
If you only want Mame then the reqs. on the comp needed is very low, if you want other emulators and PC games then you might have to get a more uptodate machine.
TalkingOctopus
    • My Arcade
« Reply #5 on: November 01, 2003, 06:42:04 pm »
Hm..... My pIII 733 cant run the mortal kombat games very well, but I am guessing your p4 would do those just fine.  I was never a MK fan anyway, but there are other examples (although not too many).
DAmnb
    • TheGameCollector
« Reply #6 on: November 02, 2003, 07:36:51 am »
Always these MK games, I just got the PC ports for MK and they work fine on my P3-733  :P
Lilwolf
« Reply #7 on: November 02, 2003, 08:01:19 am »
I enjoyed when my mame machine when from 1ghz to 2.1ghz... because then I could run area51 and a few games of that generation.
97 with 2ghz
95% with 1ghz...
90% with a 500mhz
Pick a few MUST HAVE games and ask again.
with the Pii 450... you will want to start looking at other emulators for CPS1/2 games.
