Author Topic: Cap kit... what exactly does it fix?  (Read 1784 times)
Lilwolf
« on: October 30, 2003, 12:06:57 pm »
What exactly does it fix?
washed out screens?
make them brighter?
burn in?
menace
Re:Cap kit... what exactly does it fix?
« Reply #1 on: October 30, 2003, 12:12:35 pm »
Didn't you already ask this question--ah yes sept.24 :P ;D  Same things, bad colors, low brightness things of that nature--Lets hope ken L pipes in, I'm sure he could give you a broader range of fixes with cap kits.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 30, 2003, 12:27:27 pm »
Capacitor kits (or capkits) will usually fix these problems/symptoms:
Blacking out (intermittently going dead/no video)
Uneven brightness across the face of the tube
Washed out picture
Darker than normal picture
Some focus/smearing problems
Geometric distortion ("keystoning/pincushioning")
Bars or dark bands ("jailbars")
Color edge bleeding
Lines or squiggles in picture
Horizontal and/or vertical hold problems
Most capkits cost around $10 and contain between 12 and 20 electroyltic capacitors to replace the known problem causing ones on you particular brand & model of commercial arcade video monitor. Zanen Electronics (phone: 806-793-6337) in Texas sells cap kits as does Bob Roberts.
Capkits will NOT fix:
Picture tube burn-in (that's a permanent condition that only replacing the picture tube with a brand new one will cure)
A bad yoke or flyback
Picture tube (a.k.a. CRT) with weak/bad cathodes, burnt out filament, internal shorts, or bad focus. For this type of trouble the picture tube needs to be connected to a "restorer/analyzer" like the B&K model 467 to test it's condition. If the tube is found to have a repairable condition then the restorer/analyzer can 'zap' new life into the tube.
« Last Edit: October 31, 2003, 11:16:21 am by Ken Layton »
