Author Topic: Another Bartop -Arcade Invaders- Completed  (Read 5895 times)
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« on: November 19, 2012, 02:21:02 pm »
So I started this build today as a Christmas present for my friends twin girls. Shouldn't be to much of a problem to get it finished for Christmas, but I also work full time so I can only work on this on weekends. The painting is going to be the hardest part (fingers crossed for good weather). Here's the first pic:
« Last Edit: December 18, 2012, 06:44:50 pm by Termin8tor »
Eldritch1969
Re: Another Bartop - 31 days to go
« Reply #1 on: November 19, 2012, 02:44:46 pm »
The Final Countdooooooooooooown  ;D
Reminds me of this hair band from Sweden, in the 80s  ;D
For girls, what kind of theme is it going to be ?
Good luck !
Termin8tor
« Reply #2 on: November 19, 2012, 05:10:46 pm »
Good luck !
Going to be a generic theme I'm afraid, just black sides may personalise the marquee and CP though.
Unstupid
« Reply #3 on: November 20, 2012, 04:06:37 am »
Termin8tor
Re: Another Bartop - 30 days to go
« Reply #4 on: November 20, 2012, 03:11:41 pm »
So tonight after work I managed to get some bartop time in. Iv'e glued and screwed the sides on and sealed the edges. The edges of MDF absorb paint heavily. To seal the edges spread a layer of wood glue mixed with 50% water to the edges, apply with a sponge or thin paint brush and when dry lightly sand. This helps acheive an even coat when painting.
Termin8tor
Re: Another Bartop - 29 days to go
« Reply #5 on: November 21, 2012, 09:10:47 am »
Today I have attached the top back panel and drilled vent holes.
Termin8tor
Re: Another Bartop - 23 days to go
« Reply #6 on: November 27, 2012, 07:01:40 am »
Control panel cut out and first undercoat applied.
maffewl
  • Last login:June 05, 2020, 03:11:44 pm
« Reply #7 on: November 27, 2012, 09:29:45 am »
Looking good!
Is that spray paint?  And if you don't mind me asking, what color... it doesn't quite look black and has a slight blue sheen in the picture.  I might have to buy some for my build.  :cheers:
Termin8tor
« Reply #8 on: November 27, 2012, 09:45:36 am »
Looking good!
It's a spray primer, I'm using black because the top coat will be a black gloss.
maffewl
« Reply #9 on: November 27, 2012, 09:55:19 am »
Nice.  I think you have inspired me to give a "midnight blue" shade a look.
Termin8tor
« Reply #10 on: November 27, 2012, 03:26:14 pm »
Attached kettle lead to PSU to power monitor.
Inadvertently inspiring. That's me  :D
GnobarEl
  • Last login:February 21, 2019, 04:58:34 pm
Re: Another Bartop - 22 days to go
« Reply #11 on: November 28, 2012, 06:09:29 am »
Nice work,
what is the size of the LCD? Its 4:3?
Termin8tor
« Reply #12 on: November 28, 2012, 06:43:59 am »
It's a 4:3 ratio 17" monitor.
GnobarEl
« Reply #13 on: November 28, 2012, 08:13:30 am »
for this arcades, 16:9 or 4:3 ? Its the same? Witch one is preferred?
17'' is enough? Or should I go to 19'' ?
I don't have any monitor, so I'm not sure witch one I should buy.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #14 on: November 28, 2012, 08:43:34 am »
Where did you get the plans?
Termin8tor
Termin8tor
« Reply #16 on: November 28, 2012, 05:35:20 pm »
The monitor size is very important when building a cab in my opinion. The first thing I would do is build a cardboard template and judge what size is needed. I would prefer to use a 19" on this build as there will be a lot of space around the sides of the monitor but I'm trying to keep the cost down using what I have lying around.  I will use instruction cards to break up the space. If your building a 2 player with 6 buttons each I'd go with a 19" (although I'm using a 17"  :dunno ) but a 1 player would look good with a 17" or 19".
Also I'd never use a widescreen monitor (16:9) on an arcade, it's just wrong.
GnobarEl
« Reply #17 on: November 29, 2012, 04:07:49 am »
Thanks for your advice! I'm really new here. I've read the mutch as I can but I still have so many questions.
I agree with your comments, 16:9 is out of question. I don't have any TFT so I have to buy one, I will go for the 19''.
Termin8tor
Re: Another Bartop - 16 days to go
« Reply #18 on: December 04, 2012, 12:25:32 pm »
Today I've been concentrating on the control panel. I've painted the panel, then drilled 28mm holes for the buttons and joysticks and covered with a vinyl sheet. I've also cut a piece of lexan for the overlay and to protect the artwork.
Termin8tor
Re: Another Bartop - 14 days to go
« Reply #19 on: December 06, 2012, 03:48:54 pm »
Buttons and joysticks came in the post today. Also decided on a theme.
GnobarEl
Re: Another Bartop -Arcade Invaders- 14 days to go
« Reply #20 on: December 06, 2012, 05:24:17 pm »
Witch is the common number of buttons for 2 players?
Termin8tor
« Reply #21 on: December 06, 2012, 05:35:14 pm »
Depends on the games you play. I play street fighter more than any game, so I always go with 6 per player.
GnobarEl
« Reply #22 on: December 06, 2012, 05:38:01 pm »
Yes,
I was thinking something like this:
- 6 player1
- 6 player 2
- Coin
- Pause
- Reset
- \ (for volume)
- Shift (read somewhere to use it)
- Esc
- Tab
- Enter
What do you think about it?
  • Last login:Today at 05:14:01 am
« Reply #23 on: December 06, 2012, 06:25:42 pm »
- 6 player1
- 6 player 2
- Coin
- Pause
- Reset
- \ (for volume)
- Esc
- Tab
- Enter
You may want to have a coin button for P2 as well since some games like Simpsons and Gauntlet assign credits based on which coin slot is used.
Not sure about reset.  How often do you expect it to lock up on you?
For volume, is the "/" used for mute?   How do you plan to turn the volume up/down with just one button?
The shift keys are for pinball flippers if you want to run Visual Pinball/Future Pinball.
Most people who use "shifted functions" do it to keep kids/friends from messing with the config menus or avoid having numerous admin buttons.
Examples of default shifted functions on an I-Pac include:
P1 Start + P1 Right = Tab (Menu)
P1 Start + P2 Start = Esc (Exit)
If you decide to use shifted functions in place of some dedicated admin buttons, you will probably want an instruction card on the bezel for guests.
Termin8tor
« Reply #24 on: December 06, 2012, 06:30:46 pm »
- 6 player1
- 6 player 2
- Coin
- Pause
- Reset
- \ (for volume)
- Esc
- Tab
- Enter
Couldn't of said it better myself.
GnobarEl
« Reply #25 on: December 06, 2012, 06:36:00 pm »
- 6 player1
- 6 player 2
- Coin
- Pause
- Reset
- \ (for volume)
- Esc
- Tab
- Enter
[GnobarEl]
That's a good advice, thanks!
[GnobarEl]
Thats true!
[GnobarEl]
with last version on MAME you can press \ and with left / right joystick, you can increase or decrease the volume
[GnobarEl]
I think I will not have flippers.
[GnobarEl]
I will read more about this subject!
Thanks for your advises!
Termin8tor
Re: Another Bartop -Arcade Invaders- 11 days to go
« Reply #26 on: December 09, 2012, 04:08:19 pm »
Managed to get a fair bit done today. Fitted Monitor and most internals. Grounded the PSU to the motherboard and attached the speaker shelf.
« Last Edit: December 09, 2012, 04:11:17 pm by Termin8tor »
Termin8tor
Re: Another Bartop -Arcade Invaders- 6 days to go
« Reply #27 on: December 18, 2012, 06:44:24 pm »
Completed with 2 days to spare.
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
Re: Another Bartop -Arcade Invaders- Completed
« Reply #28 on: December 18, 2012, 11:37:26 pm »
I like the monochrome/high-contrast styling.
