Author Topic: Suzo Inductive Joysticks (custom made) For Sale  (Read 2952 times)
Monty
  • Last login:June 17, 2014, 06:29:17 pm
« on: November 07, 2012, 02:55:09 pm »
« Last Edit: November 07, 2012, 06:40:55 pm by Monty »
Monty
Gray_Area
  • -Banned-
  • -Banned-
Re: Suzo Inductive Joysticks (custom made) For Sale
« Reply #2 on: January 18, 2013, 11:55:11 pm »
That's it, you changed out the shafts (which are not visible anyways) ?
-Banned-
Monty
« Reply #3 on: February 11, 2013, 07:44:21 am »
From this:
http://www.ebay.co.uk/itm/271148133646?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
To this:
http://www.ebay.co.uk/itm/271148133647?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
You Get:
1 Suzo Inductive Joystick (brand new never used)
1 Stainless Steel Custom Made Shaft
1 Ferrite Ring
1 Sanwa LB-35 Red Balltop Handle (not meshball)
1 Sanwa Shaft Cover
1 Dust Washer JLF-CD
Some info about these joystick:
Instead of using conventional microswitches, Suzo Inductive sticks employ the use of a ferrite ring at the base of the joystick shaft. An oscillating magnetic field is induced in the ferrite ring by the main coil in the centre of the PCB around the opening. This oscillating field within the ferrite ring induces a current in one or more of the eight smaller coils on the PCB. The exact position of the joystick is determined by the strength of the current in each coil. A potentiometer can be adjusted so that diagonal positions are ignored (resulting in 4-way output) or that diagonals are accepted (resulting in 8-way output.) The sensitivity of 8-way operation can be refined using the potentiometer. It is completely silent and is easily switchable between 4-way and 8-way using the aforementioned pot located on the bottom plate of the joystick.
It has an octagonal restrictor to assist in locating the desired directions. There are 6 pins for the connection which are labeled on the bottom plate of the joystick: Ground/Earth; +5 VDC; Left; Right; Up; Down. It is a short throw joystick with a max travel of 5 degrees from centre. The joystick is designed to be undermounted without taking the joystick apart; this requires a hole in the panel approx 44 mm or 1 3/4". The joystick handle was produced in two sizes, a 32 mm ball handle (suitable for cocktail cabinets), and a 38 mm ball handle. This joystick is no longer produced but as of May 2006 some were still available from Groovy Game Gear and TNT Amusements.
sethiano
  • Last login:August 20, 2014, 03:13:29 pm
« Reply #4 on: August 25, 2013, 02:40:14 am »
Any change you still know where to find this? Looking for custom shaft + stick +  ferrite core for custom shaft. please let me know
sethacowell@gmail.com
Monty
« Last Edit: September 07, 2013, 06:37:11 am by Monty »
