Author Topic: GroovyMame and CP Wizard?  (Read 3168 times)
Endprodukt
  • Last login:June 12, 2025, 01:58:29 pm
« on: November 05, 2012, 09:37:31 am »
Hey,
has anyone gotten those to work together? Is it even possible with the resolution switching? When I exit CP Wizard it will return to mame and I can hear the sound but the picture stands still. I use the "detect pause" setting. I'm on XP64.
Calamity
  • Moderator
  • Last login:May 23, 2025, 06:07:25 am
  • Quote me with care
Re: GroovyMame and CP Wizard?
« Reply #1 on: November 05, 2012, 11:48:39 am »
Well, I'm not really sure how the CP Wizard actually works, though by reading its web I think it kind of shows some graphics during pause (?), so that definitely can conflict with GM's multithreaded rendering which is *very* delicate and can easily lead to a deadlock if not treated gently. So what I'd try is to use the -nomt option in order to disable multithreading if you're going to use this.
Steps to create a log:
Endprodukt
« Reply #2 on: November 05, 2012, 06:19:11 pm »
It will give you additional info as movelists and you can set up a control panel. somehow I got it working and it doesn't seem to conflict anymore.
