Author Topic: GensFE and MAMEWah  (Read 1399 times)
EggZilla
  • Last login:January 17, 2004, 04:44:20 pm
GensFE and MAMEWah
« on: October 27, 2003, 03:25:48 pm »
Seems like a match made in heaven, but I have one complication. Some of my games are bin files, and some are smd. Thus, I can generate lists that contain one file type or the other, but not both. I've currently got them set up as two separate emulators, but does anyone know of a way for me to get MAMEWah to list both file types simultaneously?
I was thinking I might zip all the files and tell MAMEWah to look for that file extension, but it would be quite time consuming to zip each file individually. Is anyone aware of a quick fix that I'm just to dense to notice?
Cheers,
Eric
Like a bird on a wire,
  Like a drunk in a midnight choir,
   I have tried, in my way,
      To be free.
          - Leonard Cohen
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
Re:GensFE and MAMEWah
« Reply #1 on: October 27, 2003, 07:25:18 pm »
i remember a few people here have used a zip utility that zipped a folders contents into seperate zip files. i have no idea what the name of it is, and after doing a search for it...i still don't know (i would like it as well).  can anyone tell me the name of the program please?
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
« Reply #2 on: October 28, 2003, 05:06:01 am »
I'd recommend zipping them as Luxury says.
But you could try setting the ROM Extension to '*', and try that.  I can't remember if Gens requires the ROM Extension to be sent (quite possibly), but if not, it should work.
« Last Edit: October 28, 2003, 05:06:21 am by Minwah »
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #3 on: October 31, 2003, 10:09:53 am »
Check Zophar.net, I pretty sure there is a SMD <-> BIN convert tool floating around.
EggZilla
« Reply #4 on: October 31, 2003, 12:55:16 pm »
Actually, I just did it manually. I didn't have a great many files, and with WinZip in my right-click menu, it only ended up taking about 15 minutes. Thanks to everyone for your advice though - it works flawlessly now!
EggZ
      To be free.
          - Leonard Cohen
