Author Topic: cap kit  (Read 1418 times)
shumph
  • Last login:December 23, 2003, 05:24:03 pm
cap kit
« on: October 26, 2003, 10:40:22 am »
ive searched through about 20 pages of the monitor forum every website i can find, and still cant find the answer.
what all comes with a cap kit for a Matsushita tm202g monitor?
and will cap kit fix the promblem i am having?
the problem is screen starts "waving" like a flag, seems like right half of screen gets pushed up a bit. the adjustment for it just stops short of correcting it.
menace
Re:cap kit
« Reply #1 on: October 26, 2003, 11:43:50 am »
A cap kit is a bunch of electrolytic capacitors with the same size and voltage rating as those on your main chassis board--its a little different for every monitor--you could make one yourself if you were so inclined--As far as fixing your problem--it might not help but it certainly won't hurt (how's that for an answer :P) in all seriousness though depending on the age of the monitor its usually a good place to start and when you are done you're image quality IS improved.
Ken Layton
  • Guru
  • Technician
Re:cap kit
« Reply #2 on: October 26, 2003, 11:54:14 am »
The capkit usually has the caps that are known to give the most trouble. For most monitors it contains between 13 to 19 electrolytic capacitors (depending on model & make). These replacements generally will be the same value (capacity) and the same (or higher) voltage rating. Flagging can be a sign of the horizontal hold circuit having a problem (bad capacitors!). A cap kit would be the first choice to have done to your monitor and they cost around $10 for the kit.
Do the kit and you'll be surprised at the difference in the picture!
