Author Topic: Zinc to Mame default controls?  (Read 1882 times)
Fuzzguitar
  • Last login:November 26, 2012, 12:15:34 am
« on: October 22, 2003, 08:04:04 am »
Just got Zinc up and running using the command prompt and I need to know how to change the default controls to match mame so i can use it in my cab via MameWah.
I configured the graphics options by opening the renderer.cfg with notepad and making the necessary changes but that technique did not work with the controls.
I realise there is a "how to" write a controller plug in but it is too advanced for me atm - surely there must be a simpler way?
I know my girlfriend will want to play tetris and I wanna play rival schools!
Thanks in advance (again)
The Fuzz.
"My cab is nearly finished, no really I swear!"
Re:Zinc to Mame default controls?
« Reply #1 on: October 22, 2003, 09:45:07 am »
The easiest way is to use a specific ZiNc frontend to configure it, then use MAMEWAH (or other FE) once configured...
I used Aldo's ZiNc FE, it worked very well, try a search for it :)
Fuzzguitar
« Reply #2 on: October 23, 2003, 05:06:10 am »
Hey thanks,
                      That is exactly what I was going to do - I even d/l daFreaks GUI. I sort of wanted to work it out the real way... since teaching myself about the command prompt I guess I was feeling confident. But now I'm just going to go with what you mentioned.
Thanks again Minwah!
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #3 on: October 23, 2003, 11:48:08 am »
On a related note, we may not have to do this for very much longer.  I saw MAME WIP reporting Tekken & Tekken 2 are now working!!
gthyb
  • Last login:September 27, 2004, 01:38:26 pm
« Reply #4 on: November 03, 2003, 01:21:29 am »
i'm also trying to get zinc working with mamewah.  do you select the frontend's exe inside of mamewah?  because using zinc.exe hasn't been working for me.
« Reply #5 on: November 03, 2003, 05:52:38 am »
You need to use Howards commandline wrapper - www.oscarcontrols.com/lazarus.
This is because zinc launches using numbers, not romnames.
