Author Topic: Imaging my blitz 2000!  (Read 4524 times)
Need help!
« on: April 27, 2002, 09:44:22 am »
I recently bought a Blitz 2000 arcade for home, and upon opening it up, I noticed there's a PC hard drive in it!
Just to be on the safe side, I'd like to take an image of the hard drive, so I can have the possibility of restoring on a new drive should the current one fail.
Can anyone help?
planetjay
  • Last login:April 22, 2019, 10:50:57 pm
  • Ex-Evil Admin Monkey.
    • planetjay.com
Re: Imaging my blitz 2000!
« Reply #1 on: April 27, 2002, 11:08:18 am »
I've heard from a local operator that you can't. I think I'd try Norton Ghost myself.  ;)
planetjay.com. Still in Chicago. Still no hurricanes!
Lilwolf
« Reply #2 on: April 27, 2002, 11:31:57 pm »
I have no clue if it's doable..
but if I was going to try it, I would add the drive as a secondary to a linux partition.  Then copy it that way.  Linux can copy other drives better then most operation systems.
(assuming of course that you don't have a professional drive cloning device..)
Need help!
« Reply #3 on: April 28, 2002, 12:51:55 am »
Thanks - I tried Drive Image, and the drive comes up as 0MB and I can't seem to get it going.
Are there imaging tools I can try in Linux?
Lilwolf
« Reply #4 on: April 28, 2002, 08:52:39 pm »
I will try to find out the name of the tools from my boss.
but he is able to copy/clone a ton of drives for work related stuff (that can't be done in the native OS).  I think it reads the drive bit by bit and copies it that way.
Might only work with drives of the same size / type (all I'm sure hes done)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: April 28, 2002, 09:19:12 pm »
Need help!
« Reply #6 on: April 29, 2002, 10:31:21 pm »
It definitely is a standard computer hard drive.  It's a Quantum 8.4GB drive I believe and its got master/slave jumpers like a standard drive.
On my PC, I've got WinXP running Drive Image Pro 4.0, it sees the size of the drive, but I cannot image it as it says the partition is 'unallocated space'.
I am really worried that with the game on always on and over time I might have a physical problem with the drive and have to spend tons of money to get a replacement drive with the game installed on the drive.
SirPoonga
  • Puck'em Up
« Reply #7 on: April 29, 2002, 10:42:10 pm »
Hmm, probably not fat32 or ntfs then.  I'd see if you can get ahold of a linux install disk.  Just get to the portion of the install that uses disk druid or fdisk, DON'T ACTUALLY INSTALL.  When you get to that part you see everything.   Though I be someone else will have a better idea that just invalves a boot disk of some sort.
Need help!
« Reply #8 on: April 30, 2002, 09:32:31 pm »
Thanks, I can try that, but are there any imaging tools for Linux?
Lilwolf
« Reply #9 on: May 01, 2002, 12:26:55 pm »
diskman rawread and rawwrite should do it in windows
I think there was a microsoft version of the same thing in 98/95/me but I'm at a 2000 box right now
dd is the linux program that will perfectly copy any drive (as long as the output drive is the same)
Need help!
« Reply #10 on: May 01, 2002, 10:22:16 pm »
Wow, thanks!
One problem, not a big Linux guy myself, so I apologize in advance for the stupid question.
Basically I would have to set up a Linux machine (any distribution, version?), mount this slave drive that happens to be the original Blitz hard drive and run DD to image the hard drive?
SirPoonga
  • Puck'em Up
« Reply #11 on: May 03, 2002, 04:53:32 pm »
basically, you know you will have to probably mount the drive.  Make sure to read the dd man pages and howtos.
