Author Topic: Party On!  (Read 5099 times)
Goose
  • Last login:October 05, 2012, 06:04:26 pm
Party On!
« on: May 02, 2002, 08:15:27 pm »
I have Party On! in my start up directory so that it starts when windows begins.
Frobozz
  • Last login:November 15, 2002, 03:16:45 am
  • I've been sane, but then I got better.
Re: Party On!
« Reply #1 on: May 02, 2002, 09:38:34 pm »
Please excuse my ignorance, but what is Party On?
Zipper
  • Last login:May 11, 2024, 09:49:36 am
  • I've Built My Own Arcade Controls!!
Re: Party On!
« Reply #2 on: May 03, 2002, 02:38:12 am »
It's a FE.
It sounds like your problem is that something is loading AFTER Party On when you start-up, and that is shifting focus away from it.
Maybe clear any unwanted stuff out of your Start-Up folder and see if that works. Maybe there is a way of re-ordering the sequence in which they load?
Hope this helps.
Skeleton
  • Last login:September 26, 2002, 05:45:22 pm
    • Skeleton's Arcade
Re: Party On!
« Reply #3 on: May 03, 2002, 05:25:49 am »
Yep, I had the same problem with PartyOn. I also had trouble getting focus back to PartyOn after launching some programs from it. I solved it was by creating an AutoIt script that restores focus to PartyOn.  You'll need to download AutoIt (great, free, simple to use scripting program for windows) at http://www.hiddensoft.com/AutoIt/  Download the AutoIt script I wrote from the Magma downloads section of my site at http://www.geocities.com/emu_skeleton/
To use it on startup, launch PartyOn from a batch file along with the script. To use it when launching stuff from PartyOn, launch programs from a batch file with the start /wait option and place the script on the next line of the batch file. Example:
start /wait c:\fido\fido.exe
c:\AutoIt\AutoIt Partyon.aut
When "fido.exe" is done, the batch file will resume and restore focus to PartyOn. The software page on my site may explain this a little better.
This is sort of a clunky way to do it, but it works well for me.
jginiso
  • Last login:January 23, 2009, 01:41:17 pm
Re: Party On!
« Reply #4 on: May 03, 2002, 09:05:40 am »
Did you guys have any luck getting PartyOn to work with other emmulators? I could not get it to work with Mame32 and a few others...
James
Goose
Re: Party On!
« Reply #5 on: May 03, 2002, 11:58:42 am »
Thanks Skeleton.  I will try that and let you know how I made out.
James: I have gotten Party On to run quite a few mame32 games.  You just have to be very careful with the code.  One small mistake and it won't work.  I also have Party On running some pc games, arcade jukebox, winamp and some other proggies.  I'm just in the progress of trying to get some other emulators to work with it.  Give us an example of the code that you use to launch a game and then I can compare it with my own.
Regards,
Goose
jginiso
Re: Party On!
« Reply #6 on: May 03, 2002, 12:14:16 pm »
Thanks I'll post an example of what Ive got when I get home. Ive gotten some Win/Dos programs to run but not others. IM trying to make it launch the emmulators themselves instead of specific games. According to the docs there is a -menu command that would let you do this but I cant get that to work either.
Goose
Re: Party On!
« Reply #7 on: May 03, 2002, 04:12:46 pm »
Well...that AutoIt proggie did the trick.  Thanks Skeleton.
I have another question for you.  I notice on your screenshots of Party On! that at the top of each screen you were able to put Magma.  Party On! defaults by saying Arcade Pc at the top and I have no idea how to change it.  Could you tell me how you did that?
Another question for Skeleton: How did you get your magma logo to shimmer in that Windows startup picture?
Finally a question for everyone: How do you get windows to stop asking for a login and password when it loads up?
Thanks for your help
Goose
Goose
Re: Party On!
« Reply #8 on: May 03, 2002, 04:18:11 pm »
James:  Here is an example of some of my code from Party On!  Hopefully some of it will be of use to you.
This is my code to load a single game for mame32.
Outrun|C:\snap\outrun.jpg|E:\My Documents\New Folder\Stretchmame32asm-037b15b| Stretchmame32a outrun -quit
This is my code to load the mame32 emulator frontend and not just a single game.
M.A.M.E|C:\snap\starmame1.jpg|E:\My Documents\New Folder\Stretchmame32asm-037b15b\|mame32.exe
This is my code to load up a winamp playlist.
WinAmp Playlist (new)|C:\snap\winamp1.bmp|c:\games\mame\help\astdelux.hlp|C:\proggies\Winamp\|winamp newmusicplaylist.m3u -quit
Skeleton
    • Skeleton's Arcade
Re: Party On!
« Reply #9 on: May 06, 2002, 06:18:03 am »
jginiso
Re: Party On!
« Reply #10 on: May 06, 2002, 08:32:28 am »
Thanks Goose! I knocked my head against this again this weekend for  awhile and got nowhere. I'll try your code tonight and see if I can make it work. Using batch files like skeleton suggests sounds interesting but I have no clue, so one thing at a time...
