Author Topic: Arachnid Super 6 Plus II  (Read 2990 times)
zlovell
  • Last login:November 04, 2012, 06:42:35 pm
« on: October 30, 2012, 07:07:37 pm »
Hi
I have an Arachnid Super 6 Plus II. The numbers 1 and 20 do not register. was wondering if anyone could help me.
Thanks Zita
« Last Edit: October 31, 2012, 01:11:17 am by saint »
Ken Layton
  • Guru
  • Technician
Re: Arachnid Super 6 Plus II
« Reply #1 on: October 31, 2012, 12:03:12 pm »
There are lots of threads on Arachnid dart machines here on this forum detailing the target head and it's troublesome switch matrix. But to boil it down to the basics:
Take target head apart and clean out the broken tips.
Wipe gunk off switch matrix and rubber damper (I use lighter fluid on a rag or paper towel).
Inspect the "segments" for cracks (particularly the pie wedge shaped ones). Replace any cracked segments as they will bind up inside the spider.
Sometimes the sealed switch matrix will go bad internally. This is an expensive item to replace (in the $100 range).
zlovell
« Reply #2 on: October 31, 2012, 08:13:10 pm »
Thank you very much for reply. I will check this out.
Zita
eboley
  • Newbie
  • Last login:January 31, 2013, 10:09:58 pm
« Reply #3 on: January 31, 2013, 09:50:43 pm »
Does anyone know where I could buy new segments for a Arachnid Super 6 Plus II?
