Author Topic: Cocktail Table Joysticks  (Read 6683 times)
NickS
  • Last login:September 11, 2014, 06:59:58 am
« on: June 19, 2002, 12:06:58 pm »
Can anyone recommend a place to buy Cocktail Table Style Joysticks. I am looking to build 2 Mame based Cocktail Tables in the style of Ms Pacman. One which I would like to use 4 way joystcks and the other using 8 way joysticks (to play games like Bomb Jack).
Ideally I would like them to be new with a ball style handle. If anyone can recommend anywhere I would be grateful.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re: Cocktail Table Joysticks
« Reply #1 on: June 19, 2002, 07:47:26 pm »
goto www.videoconnect.com
they have new 4 way ball handle microswitch joysticks, but they don't have leaf switch ones anymore.  They were pretty much the last place to carry those and they are all gone now. :(  But you can still get the micro switch ones.
jakobud
Newbie J
« Reply #2 on: June 20, 2002, 11:03:34 am »
Happ controls makes a 4 way / 8 way switchable joystick with a ball handle. Switch is done with a restrictor plate on underside of joystick. That way, if you ever decide to make your 4 ways into 8 ways, you can.
I think they are about $12 each.
See links for website URL.
Grasshopper
« Reply #3 on: June 20, 2002, 12:10:47 pm »
As you live in the UK (I'm guessing from your email address) I would suggest you try either the 2-4-8 way switchable Sega joysticks available from Suzo (UK) or maybe the J-Stik from Ultimarc.
Anonymously
  • Last login:May 26, 2005, 02:13:11 am
  • MarMags Arcade
« Reply #4 on: June 20, 2002, 02:28:50 pm »
J-stick from ultimarc operates in 8-way or true 4-way mode by rotating the restrictor.
Just check it out Here
No Offense, it's just a suggestion
