Author Topic: Advice on bonding wood...should I use bondo and how much of a gap??  (Read 4034 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
Currently redoing the bottom on my cab and getting rid of the rot. So we made a replica bottom and plan on doing a frame on the inside to keep it sturdy however we wanted to bondo the seam and wasnt sure about the gap to leave room for the bondo..looking for ideas and advice on
Now here is our question...how much of gap should we leave for the bondo to fill in?? We left a penny inbetween for now..nothing it screwed together yet..
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
yaksplat
    • Random Projects
Re: Advice on bonding wood...should I use bondo and how much of a gap??
« Reply #1 on: October 03, 2012, 11:30:28 am »
I don't think i'd leave a gap.  If anything I'd put a slight chamfer on the two boards, maybe an eighth inch, and glue and clamp the boards together.  After the glue dries, then fill the chamferd gap with bondo and sand it out.
Bonding hardwood together like this, i just use biscuits or dowels and then glue, clamp and sand.  I prefer biscuits since dowel alignment is tough. 1/64" off is noticable.
http://yaksplat.wordpress.com
willybeamish
« Reply #2 on: October 03, 2012, 11:42:31 am »
Sounds like a good idea...The dowels is a great suggestion too!!!
yaksplat
    • Random Projects
« Reply #3 on: October 03, 2012, 12:06:23 pm »
I advise against dowels on butt joints.  You may end up with a noticable ridge that you can't sand off.
  • Last login:Yesterday at 08:12:36 pm
« Reply #4 on: October 03, 2012, 02:13:45 pm »
What a great tip!
Mysterioii
  • Last login:August 31, 2018, 11:44:34 am
« Reply #5 on: October 03, 2012, 02:23:41 pm »
I strongly suspect that Yaksplat really knows his shizz.   :cheers:  I was all set to reply with my own suggestions only to see that he'd already covered everything I was about to suggest and more.
willybeamish
Re: Re: Advice on bonding wood...should I use bondo and how much of a gap??
« Reply #6 on: October 03, 2012, 02:53:58 pm »
I'll check with my pops I'm sure he has the tools to do the biscuit joints
« Reply #7 on: October 03, 2012, 03:07:08 pm »
Any man that uses a Ron Swanson pic as his avatar definately knows his ---steaming pile of meadow muffin---.
willybeamish
« Reply #8 on: October 03, 2012, 03:11:58 pm »
I agree there's something about that face that screams do what I tell you
willybeamish
« Reply #9 on: October 03, 2012, 10:45:28 pm »
We did biscuits and glue Ron don't worry lol
