Author Topic: How to measure radius?  (Read 2529 times)
mbasile35
  • Last login:June 27, 2017, 09:14:04 pm
« on: September 28, 2012, 07:26:58 pm »
Hey everyone
I'm trying to flush mount a happ 4 speed shifter into a panel and i'm wondering how can i measure the radius of the corners to get the shifter plate to sit perfectly into the panel. The shifter is this one http://na.suzohapp.com/driving/50849600e.htm. Is there some kind of tool to measure radius? Do i just eyeball it?
Mike
Re: How to measure radius?
« Reply #1 on: September 28, 2012, 07:46:05 pm »
The drawing says that the corner radius is .13"
Or are you talking about something else?
SavannahLion
« Reply #2 on: September 28, 2012, 07:48:41 pm »
http://www.handymath.com/cgi-bin/rad2.cgi?submit=Entry
I think last time I did something that small, I just penciled it then went through my drill bits until i found one that fit and drilled the corners first. Came out OK.
mcseforsale
  • Last login:August 14, 2025, 10:40:54 am
  • Creepy Mario Dude
« Reply #3 on: October 02, 2012, 12:32:59 pm »
Damn...I've used CDs, quarters, my tire pressure gauge.  Whatever I can find.  HAHAHA.
AJ
selfie
« Reply #4 on: October 02, 2012, 06:22:46 pm »
+1  Drill bits is how I do it for small stuff.
yaksplat
    • Random Projects
« Reply #5 on: October 03, 2012, 11:43:39 am »
use a square
If you put a square on the corner, the measurement of the gap is the measurement of the radius.
http://yaksplat.wordpress.com
