Author Topic: Megatouch Maxx Battery Replacement  (Read 16209 times)
jpusa
  • Last login:September 28, 2012, 11:39:42 am
« on: September 25, 2012, 09:50:57 pm »
Saw a couple other posts on here about Megatouch and thought I would throw this out to see if anyone is familiar with them... I've been having problems with my Megatouch Maxx, Unicorn board, needing the cmos time and date reset every time I leave it off for a few days. I'm trying to replace the motherboard battery, but I can't find it for the life of me. Any ideas? Thanks!
ed12
Re: Megatouch Maxx Battery Replacement
« Reply #1 on: September 25, 2012, 11:29:18 pm »
hi
as a rule under the riser card
the batt will be right there
ed
jpusa
« Reply #2 on: September 28, 2012, 11:40:22 am »
Gilles54
  • Last login:March 12, 2015, 01:34:56 pm
  • Just like Heaven !
« Reply #3 on: October 05, 2014, 05:58:02 am »
Hi!
Very same problem, i can't find the battery  :angry:
Its a megatouch maxx, telco 586 motherbord with millenium "heavy" i/o card.  Telco riser card.
I removed the i/o board to triple check i wasnt missing the battery below but i can't see it !
Maybe it s not the usual cr2032 battery type ?  That would explain i dont see it ...
Many thx.
ed12
« Reply #4 on: October 05, 2014, 12:16:43 pm »
cr2032
straight bios bat
ed
Gilles54
« Reply #5 on: October 05, 2014, 02:52:15 pm »
cr2032
straight bios bat
ed
It is crazy i cant see it  :banghead:
Going to post a picture of the mobo later on.
ed12
« Reply #6 on: October 05, 2014, 02:57:53 pm »
should be right on main mobo
ed
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #7 on: October 05, 2014, 11:06:51 pm »
I agree with ed on here.
That battery is standard coin battery, used on just about every standard computer motherboard ever built.
Should be pretty easy to spot.
Gilles54
« Reply #8 on: October 06, 2014, 03:30:48 am »
Should be yeah ...
Mobo without i/o & riser board : https://imageshack.com/i/iqhjiP1bj
  • Last login:Today at 04:12:26 pm
« Reply #9 on: October 06, 2014, 03:38:54 am »
Clicked on the link, but no pic comes up.   :dunno
Gilles54
« Reply #10 on: October 06, 2014, 03:40:57 am »
Works fine here.  This is odd.
Upped to another host : http://hpics.li/6474c84
Better ?
« Reply #11 on: October 06, 2014, 03:42:11 am »
That works.   ;D
« Reply #12 on: October 06, 2014, 04:16:39 am »
I don't see a 2032 in that photo, either.   :dunno
3 possibilities:
  1. It's under the metal riser on the left (a smaller form factor battery would be easier to hide this way)
  2. It's on the back of the MB
  3. There is an external battery pack with two wires leading to the MB
Gilles54
« Reply #13 on: October 06, 2014, 04:42:13 am »
3 possibilities:
Thanks for your input :
1. Already checked, No. ( pic : http://hpics.li/b31d0d7 )
2. Already checked, No.
3. Checked and dont see anything like that.
Sarver Systems
« Reply #14 on: October 06, 2014, 07:34:08 am »
Gilles54
« Reply #15 on: October 06, 2014, 07:42:23 am »
Might be of use: http://www.meritgames.com/Support_Center/manuals/board%20id.pdf
Thanks but i already checked that.
You can see the picture of the same motherboard as the one i have, but you dont see any battery either...
  • Last login:November 21, 2025, 10:39:28 am
« Reply #16 on: October 06, 2014, 09:07:59 am »
This megatouch maxx has it on the I/O board.
Different mobo and it sticks out like a sore thumb, but  :dunno
(and I don't see a key on the board either)
EDIT: upon reading the thread, what looks like a battery may have been the key)
http://forum.arcadecontrols.com/index.php?topic=115530.0
I've broken the arm on those battery holders before and ran leads to a battery.
Previous owner could have done the same and cleverly disguised it.
« Last Edit: October 06, 2014, 09:13:52 am by BadMouth »
Gilles54
« Reply #17 on: October 06, 2014, 09:19:53 am »
Yep well here are picture of my i/o.
http://hpics.li/a7da0cd
http://hpics.li/1cb70d9
Beside the dongle i see no battery..
« Last Edit: October 06, 2014, 09:21:43 am by Gilles54 »
ed12
« Reply #18 on: October 06, 2014, 11:05:47 am »
what u are seeing as a bat is indeed the key.
u have to remove the riser card to get to the bios bat
about that simple
ed
Gilles54
« Reply #19 on: October 06, 2014, 11:19:14 am »
about that simple
ed
I think you got it wrong.
The pic above is from Badmouth not from my game.
My mobo & i/o are completely different.
Like i said above i already removed the riser board.  There is no battery on the motherboard.
Links to my motherboard again :
i/o board:
If you see a battery there plz let me know where.
« Last Edit: October 06, 2014, 11:23:26 am by Gilles54 »
ed12
« Reply #20 on: October 06, 2014, 11:32:05 am »
do u see the 4 chip's in a row just about in the middle of the mobo ?
from top down the 3rd chip is your batt
get a colser pic of it
it might be a dallas chip ? or just any ol bat back-up
just need the # off of it
ed
Gilles54
« Reply #21 on: October 06, 2014, 12:03:41 pm »
Looks like it.
Odin oec12b887a
ed12
« Reply #22 on: October 06, 2014, 12:26:17 pm »
yup made by dallas
ed
Sarver Systems
« Reply #23 on: October 06, 2014, 12:44:25 pm »
Good ole Dallas Chip.
Yeah, good luck with that!
ed12
« Reply #24 on: October 06, 2014, 12:54:13 pm »
u can still get them
if u have a problem ? ring me up
i will list the dallas cross ref for u
ed
Gilles54
« Reply #25 on: October 06, 2014, 12:58:53 pm »
http://fr.aliexpress.com/item/OEC12B887A/1358541591.html
Simply desolder and solder, nothing too complex right ?
Sarver Systems
« Reply #26 on: October 06, 2014, 01:51:35 pm »
I was thinking these had the bit of code that had to be programmed or matched the mainboard.
ed12
« Reply #27 on: October 06, 2014, 02:55:17 pm »
not in this case sarver time-keeping/bios setting's
the @ may want to chk as 90% of them i have seen were in socket's
ed
Sarver Systems
« Reply #28 on: October 07, 2014, 12:41:42 pm »
If its socketed...that would be awesome.
If not...but a socket with the chip!
