Author Topic: How to compile Groovymame Linux 32/64 bits  (Read 3897 times)
Rockman
  • Last login:January 30, 2014, 12:10:33 pm
« on: September 25, 2012, 08:03:23 am »
Someone can write a quick mini tutorial to compile Groovymame Linux for the people? How to create the correct compiling environment, where to donwload the compilers and required files, and a step by step guide? Is possible compiling it from Window$?
Or someone can upload somewhere a ready compiling environment ready to use?
Thanks in Advance  :notworthy:
ves
  • Last login:April 11, 2020, 02:57:49 am
Re: How to compile Groovymame Linux 32/64 bits
« Reply #1 on: September 25, 2012, 09:35:10 am »
Hello, you just need to compile the source code, and run this command:
make NOWERROR=1 OPTIMIZE=2
And this if you want the utilities
make tools NOWERROR=1 OPTIMIZE=2
Optimize used for a bug in gcc 4.7, more info in the links
https://bugs.archlinux.org/task/29986?project=5&cat
Rockman
« Reply #2 on: September 25, 2012, 06:12:29 pm »
Thank you Ves. (One more time!)  :notworthy:
Calamity
  • Moderator
  • Last login:Yesterday at 05:56:31 pm
  • Quote me with care
« Reply #3 on: September 26, 2012, 06:27:13 am »
I'll just add that GroovyArcade already contains gcc, so you don't need to install anything in order to compile.
Steps to create a log:
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
« Reply #4 on: August 03, 2013, 10:45:25 pm »
Quick FYI. I needed to install QT package.
pacman -S qt
machyavel
  • Last login:December 25, 2016, 10:23:52 am
« Reply #5 on: August 05, 2013, 08:02:01 pm »
Take a look here "http://forum.arcadecontrols.com/index.php/topic,129890.msg1357945.html#msg1357945"
moreover, to avoid the need of installing QT you should disable debug option in "source\src\osd\sdl\sdl.mak":
# uncomment to disable the Qt debugger and fall back to a system default
# NO_USE_QTDEBUG = 1
