Author Topic: command.dat  (Read 1178 times)
wcndave
  • Last login:June 10, 2021, 03:37:36 am
command.dat
« on: September 21, 2012, 12:33:34 pm »
I came upon a command.dat file.  it looks interesting.  I searched on the forum and found nothing.
it looks like I can use it to derive moves? like combos etc.  or is it to tell the system what the moves are?
how would i use something like this:
Code: [Select]
[Common Commands]
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
:Movement:
Dash                                   _L/^U
Retreat                            _M/_4_+^U
:Jumps:
Super Jump                           _2_8/^T
:Escape Moves:
Advancing Guard                      block^U
Safety Roll               when landing_s_+^?
:Variable Attacks:
Variable Assist                       ^F_+^I
Variable Attack                       ^G_+^J
Variable Counter             block_s_+^G_+^J
  * needs 1 Level
Variable Combo                    _t_+^G_+^J
  * needs 2 Levels
$end
$cmd
[Combo Info]
Punch-to-Kick:      ^E/^F/^G_!^H/^I/^J(2hit)
Kick-to-Punch:      ^H/^I/^J_!^E/^F/^G(2hit)
Weak Start:         ^E/^H_!^F/^I/^G/^J(2hit)
Stronger:          ^E/^H_!^F/^I_!^G/^J(3hit)
Zig-Zag:        ^E_!^H_!^F_!^I_!^G_!^J(6hit)
$end
$cmd
[Spiderman/Armor Spider-Man------------]
 * Armor Spider-Man is a Secret Character *
   * At the Character Select Screen, put *
        * the cursor on Ryu_O_S,^2 *
  * for 5 seconds and press^E_+^G/^H_+^J *
sorry if this is really noob  :-[
  • Last login:August 19, 2025, 03:10:32 pm
Re: command.dat
« Reply #1 on: September 21, 2012, 01:21:15 pm »
http://lmgtfy.com/?q=command.dat
also works with CPWizard
http://headsoft.com.au/index.php?category=cpwizard
I tried it with MAMEPlus long ago and it worked, not sure if it's still supported.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Re: command.dat
« Reply #2 on: September 21, 2012, 01:32:38 pm »
It's still supported in mameplus
Sent from my Desire HD
