Author Topic: Hantarex Polo3 Sync Problem  (Read 1144 times)
Arcade-TV
  • Last login:April 12, 2025, 08:04:07 am
« on: September 14, 2012, 04:58:58 pm »
http://youtu.be/7QR3IZgxN4k?hd=1
I have wired so many cabs that I accidently managed to mixup parts- and solderside for video on the jamma connector... now i did the wiring right, tested continuity and all but the screen won't sync. I tried combinations of hs only, hs and vs on cn7 on the monitor, i'm afraid i'm missing something... or i damaged it when i first powered on with the mixed up wires.
can anybody take a look at the video and tell me if this looks familiar to you?
it's a hantarex polo3/15kHz 14" screen.
thanks!!!
grantspain
Re: Hantarex Polo3 Sync Problem
« Reply #1 on: September 14, 2012, 05:58:47 pm »
if its a multigame pcb then use pin 1 as video ground or link 14 and 1
that looks video ground missing rather than sync issue
Arcade-TV
« Reply #2 on: September 14, 2012, 06:03:44 pm »
that's what i was guessing but haven't tried yet.
yes, it's one of those crappy 60-in-1.
i'll report back when i added ground to pin 14.
THANKS!!!!!
Arcade-TV
« Reply #3 on: September 21, 2012, 06:46:45 am »
This was pretty hard...
I rewired the thing four times, used different PSUs, changed the ground-wiring and and and...
In the end... the darn pcb was faulty, replaced it and everything was in working order.
Thanks for the advice with the video ground though!
http://youtu.be/6-tzXgrxl6M?hd=1
