Author Topic: Default Marquee and Starting Picture have me pulling my hair out  (Read 3051 times)
« on: September 06, 2012, 11:20:11 pm »
I set them in my layout using layout editor...
Opened the mll file in notepad and made sure the path to my images was correct.  Checked and unchecked all different options under the GUI tab.
Still nothing... WTF am I doing wrong?
Re: Default Marquee and Starting Picture have me pulling my hair out
« Reply #1 on: September 07, 2012, 12:52:31 am »
Alright found the check box under the "GUI" tab Game Start/Quit Sub-Tab for using the starting pic if called to by the layout.  That fixed my Starting picture issue.
Still lost on the default marquee.  :angry:  :angry:  :banghead: :banghead: :banghead:
« Last Edit: September 07, 2012, 01:12:48 am by harveybirdman »
« Reply #2 on: September 07, 2012, 08:04:10 am »
Well, just verified that the marquee does still work (in the 1.7.5 beta anyway).
Here's the entries from my mll file
MarqueeImageTop=54
MarqueeImageLeft=187
MarqueeImageHeight=450
MarqueeImageWidth=450
MarqueeVisible=1
Note that I didn't put a path on the DefaultMarquee.jpg, and I also set mala to NOT use the layout name as folder
My Mala.INI section looks like this
[Layout]
SelectedLayout=No18Arqadium
SwitchWithEmulator=0
SwitchWithGamelist=0
UseLayoutNameAsDir=0
DisableAnimation=0
SearchDefinablesInLayoutPath=0
LayoutDirectory=C:\Games\FrontEnds\Mala\Layouts\No18Arqadium
« Reply #3 on: September 07, 2012, 08:50:54 am »
Mine has the path going to try just the filename and toggle the layout pics are in a folder of the same name switch when I get home. Thanks doc!
« Reply #4 on: September 08, 2012, 12:16:18 pm »
I couldn't get so I finally just added it to my bg image, looks great...
When I get things cleaned up I'll post layout video here.
« Reply #5 on: September 08, 2012, 12:39:48 pm »
You're using the latest 1.7.5 right?
« Reply #6 on: September 09, 2012, 05:42:07 pm »
1.7.4 actually... funny thought I had upgraded to the beta.
here's the layout (in progress) in case you missed it in the other thread.  Just added the default marquee to the background until I can upgrade MaLa or otherwise solve this.
« Reply #7 on: September 09, 2012, 09:22:47 pm »
Nice.
Yeah, I'd grab 1.7.5 if you can and have a go with it. The marquees and such seem to be working fine for me.
