Author Topic: Hyperspin HD extern ?  (Read 1766 times)
Nestafari
  • Last login:August 21, 2019, 09:08:58 am
« on: September 04, 2012, 04:43:28 pm »
Hi, is it possible to run Hyperspin from an external hard drive without slow loading or lag??
1T 7200  ;)
Space Simpsons cab in progress
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Hyperspin HD extern ?
« Reply #1 on: September 04, 2012, 06:48:13 pm »
Yep
Nestafari
« Reply #2 on: September 07, 2012, 02:59:10 pm »
That's great news !! even for Ps2 Emulator it wont lag or anything?
Thank you
Lilwolf
« Reply #3 on: September 13, 2012, 05:52:27 pm »
Hyperspin will not effect the speed of the emulator.  Once it launches a game, it will just go into suspend mode taking as little resources as possible until it gets control back
So if an emulator works fine from the command prompt, it will run the same through the frontend.
Now will the frontend run on your system is the real question.  Hyperspin is a bit of a resource hog... but thats just when moving around the wheel and drawing all the images... but once a game launches, it doesn't draw anything.
