Author Topic: Thinking about using acrylic for cocktail cabinet top  (Read 2366 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: August 27, 2012, 10:09:55 pm »
I've seen that quite a few people use a glass top for their cocktail cabinet. I have been eyeing the possibility of using acrylic. Has anyone done this before? Is it a bad idea? Why or why not?
Unstupid
Re: Thinking about using acrylic for cocktail cabinet top
« Reply #1 on: August 27, 2012, 10:38:50 pm »
Why not?  Scratches!  ;)
emb
    • Don Honerbrink
Unstupid
« Reply #3 on: August 27, 2012, 10:47:42 pm »
Yea $80 is about right.... Shipping these is problematic (especially to Hawaii) which is why I ended up paying $200 for 2.  It is worth it though.  No scratches and no sagging.  If you want to really do it right Phoenix arcade has Screened Glass like they did on the real Ms Pac tables!  $225 a pop: http://www.phoenixarcade.com/art.htm#MsPAC
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #4 on: August 28, 2012, 02:39:14 pm »
Most local glass shops will cut you a piece to shape. That's what I did, it was around $50. I definitely would not use acrylic for a cocktail, the scratches would drive me insane.
Unstupid
« Reply #5 on: August 28, 2012, 02:56:23 pm »
I'd still stick with the on-line merchants over the local glass shop because the ones you get on-line are usually tempered which makes it 4-5 times more durable and a lot safer incase it does crack.  Your local shop may be able to temper it for you but make sure you ask for it!
ahofle
    • Arcade Ambience Project
« Reply #6 on: August 28, 2012, 03:52:03 pm »
When I went through this dilemma last year, I called about 4 different local glass shops around here.  I didn't get a single quote for less than $100, and even more if you wanted it tempered.  I'm not sure where you guys are able to find a local glass shop to do custom work for you for a mere $50.  I ended up getting this tempered glass top for $59 + shipping (well worth it):
http://www.xtremegameroom.com/ms-pacman-pac-man-galaga-tron-midway-bally-cocktail-table-glass.html
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #7 on: August 28, 2012, 04:34:04 pm »
acrylic scratches way to fast , its sensitive to alcohol and other ingredients of cleaning fluids and collects dust. i usually take floatglas 6-8 mm for cocktail tables . a glas plate of 50x50 or 60x60 cm will cost around 20-25 euros with polished edges . u dont need tinted safety glas in ur private rooms .
emb
    • Don Honerbrink
« Reply #8 on: August 28, 2012, 07:15:10 pm »
You swayed me, especially when it comes to hearing the market price of this stuff from all of you. Thanks for everyone's input.
