Author Topic: Keyboard Hack  (Read 2476 times)
Bonesthedog
  • Last login:May 17, 2004, 07:59:56 pm
Keyboard Hack
« on: October 08, 2003, 10:23:00 am »
I'm trying a keyboard hack for the first time(ive only done joystick before) and i had a few questions.
There is two groups of wires on my keyboard controller. one group of 8, one of 17. when i touch one from one group to one of the other group, it creates a keystroke. so i mapped it out using keyhook. now i need to know, how do i wire it if i need more then one key on the same wire
example: 1+15 is esc, and 1+3 is 5. or 3+6 is A, and 2+6 is B. How would i go about wiring/soldering?
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Re:Keyboard Hack
« Reply #1 on: October 08, 2003, 12:58:27 pm »
The easiest way is to solder a single wire to the contact on the KB PCB...
Then attach that wire to a terminal strip with screws.
Then the wires going to your buttons would attach to the screws on ther other sire of the strip.
(See diag below)
I'm not a freak!...
Oh wait...
Yes I am...
ducky123
  • Last login:May 03, 2004, 05:13:39 pm
Re:Keyboard Hack
« Reply #2 on: October 08, 2003, 11:42:36 pm »
doesn't ghosting happen? Like when you press like 3 keys or something other keys get pressed too... I never tried it but was gonna.... when I heard about that.. is tat true?
freppa
  • Last login:September 30, 2004, 08:45:31 am
Re:Keyboard Hack
« Reply #3 on: October 09, 2003, 06:00:51 am »
Ghosting might happen if you press three or more keys at once. But only if you aren't carefull in selecting keys...  ;)
If you select keys carefully, there is no possibility of ghosting or blocking. I think Bonesthedog might be able to get 17 individual inputs, if he also selects his keys carefully he would be able to get two joysticks and 6 buttons per player with one input to spare... ::)
/freppa
paigeoliver
  • Awesome face!
Re:Keyboard Hack
« Reply #4 on: October 09, 2003, 06:11:03 am »
/freppa
Except that he wouldn't be able to press all his buttons at once. Most keyboards that I have seen won't register more than 5 or so keys held down at once.
Tiger-Heli
    • Tiger-Heli
Re:Keyboard Hack
« Reply #5 on: October 09, 2003, 06:46:01 am »
See the recently revised http://www.mameworld.net/emuadvice/keyhack2.html for how to choose the inputs to avoid ghosting.
Not true, the majority of keyboards will only register 5 or so random keys, because they employ keyblocking that keeps additional keys from registering once 3 keys that form a right triangle on the matrix are depressed.  Avoid right triangles and all 17 keys will work.
A few keyboards employ an arbitrary "pressed key maximum" of (usually 8) keys that can be pressed simultaneously, but these are much less common.  (I've never seen one, and I know at least a dozen people who've used the methods I explain, but RandyT has one and Andy Warne reported this to me originally).
Tmasman - Nice graphic.  Okay if I steal that for the NEXT revision to the above page?
tmasman
  • Hello...
Re:Keyboard Hack
« Reply #6 on: October 13, 2003, 02:25:39 pm »
Sure...
It was just a quick sketch, but if you like it, use it.
I'm not a freak!...
Oh wait...
Yes I am...
Tiger-Heli
    • Tiger-Heli
Re:Keyboard Hack
« Reply #7 on: October 14, 2003, 06:49:22 am »
Sure...
Babu
  • Last login:October 14, 2003, 10:42:46 pm
  • Boo...
Re:Keyboard Hack
« Reply #8 on: October 14, 2003, 10:46:47 pm »
Ive seen this site http://smellhound.com/mame/
there the guy says hes gonna add resistors to try to keep ghosting problems as low as possible I dont know if he knows about that stuff or he has no idea what hes talking bout. You guys tell me cause im about to go through a keyboard hack and ima try to make as best as possible. And if its true how do you know what resistors to use.
Thanx Cya
Tailgunner
Re:Keyboard Hack
« Reply #9 on: October 14, 2003, 11:04:57 pm »
Thanx Cya
I believe you'd get better results using diodes.
Tiger-Heli
    • Tiger-Heli
Re:Keyboard Hack
« Reply #10 on: October 14, 2003, 11:11:17 pm »
Thanx Cya
He's confused.  Resistors won't help anything.  Diodes might help, but only if the keyboard doesn't use blocking or  have a pressed key maximum.  Most do use blocking, though.  Even if it doesn't you can get by without diodes.
See my EmuAdvice page (above) and you'll be fine.
Babu
  • Boo...
Re:Keyboard Hack
« Reply #11 on: October 15, 2003, 06:57:55 pm »
How do I know what diode to get? And how do i set them up?
Cya
Tiger-Heli
    • Tiger-Heli
Re:Keyboard Hack
« Reply #12 on: October 16, 2003, 08:02:50 am »
Cya
AFAIK, any standard diode is fine.  You shouldn't need them.  They will only work if your keyboard shows "ghosting"  i.e. you press three keys forming a right triangle of the matrix and four keys show as depressed.  They will NOT work if your keyboard uses blocking i.e. you press three keys forming a right triangle of the matrix and the third key does not register.
Everything I know about them is in the FAQ section of the page above.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:Keyboard Hack
« Reply #13 on: October 16, 2003, 10:40:55 pm »
Diodes are pretty standard as long as it doesn't say "zener" on it.  They all drop about 0.7v.  What changes is the current they can handle, and that's only important if the diode is part of a power supply circuit.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:Keyboard Hack
« Reply #14 on: October 27, 2003, 01:56:28 pm »
I think diodes are an urban myth!
I've never seen (not once) a wiring diagram that showed how you're supposed to hook them up, nor a theory as to what they might do.
All (or nearly enough to go ahead and say "all") AT and PS2 keyboards will allow 16 simultaneous keypresses, which is exaclty enough to get 2 sticks with 6 buttons each, or 4 sticks with 2 buttons each.
You just have to be very careful to avoid "Windows" combinations, and you need to plan out implementation to avoid any blocking combos. It's easy to do by just using each line on the "long" side of the matrix once.
Usually takes me 2 hours to figgue out.
Bob
tmasman
  • Hello...
Re:Keyboard Hack
« Reply #15 on: October 27, 2003, 02:03:40 pm »
There are a handfull of sites referencing how to include diodes in your KB hack, but they are not even usefull with today's KBs... Today's KBs use blocking to avoid key ghosting... (Blocking is programmed into the IC... no hardware way to avoid it...)
So if you've got a hacked KB & are having problems... either use different keys, or a different KB...
Anyhow, have you guys seen this? It's just a hacked KB, but I don't know if this guy even knows about blocking/ghosting... He acts as though there are no problems w/ KB hacks...
Ebay auction f/ hacked & mapped KB
eh... I'm watching it to see the final price he gets... I maight have to throw a few on greedbay if he makes anything off them...  ;)
I'm not a freak!...
Oh wait...
Yes I am...
neuromancer
  • Can I Play?
Re:Keyboard Hack
« Reply #16 on: October 27, 2003, 03:54:50 pm »
Yes, I've seen references, but I've never seen details. I've tested dozens of keyboards, some as old as 1985, and every one of them had blocking. I'm beginning to think that blocking might be part of the AT Keyboard specification.
he acts as though there are no problems w/ KB hacks...
There are no problems with keyboard hacks that are properly done, and within the constraints of the hardware, but it's obvious that the guy in the link isn't aware of them, because there's no way to have 4 sticks with 4 buttons each without running into blocking.
Bob
