Author Topic: [Help Needed]Running Multiple Emuls From Mala [Demul\M2Emulator\Zinc\Mame]  (Read 2872 times)
stshepana
  • Last login:August 20, 2012, 05:27:46 pm
Coild some please help me run all this emulators from a single gamelist in Mala. I have already tried multimame and can launch three of them. But demul seems to be giving me problems.
  • Last login:January 29, 2026, 12:04:48 pm
http://forum.arcadecontrols.com/index.php/topic,121157.msg1285434.html#msg1285434
Have a look at the multiple emus in one list thread stickied at the top of this forum and my cmd file in the thread I linked above.  It only applies to Demul v.57.  If using an older version, you'll need an autohotkey script to make it go full screen.
« Last Edit: August 21, 2012, 09:11:52 am by BadMouth »
I'm actually working through that process right now.
I'm mainly interested in running several PC games from the single game list.
I'm trying to simplify it a bit over what's in that thread, but the info there is really good.
Just FYI with the 1.7.5.4 version of mala, the %path% argument that you should be able to pass on the command line doesn't appear to work. That would explain any problems with this approach.
I've posted another thread inquiring about that problem. Hopefully, loadman will have some time to check it out.
