Author Topic: Epsxe won't diplay in Mala properly  (Read 2306 times)
EvanW
  • Last login:April 23, 2018, 10:39:31 pm
« on: August 13, 2012, 03:27:32 pm »
Gents,
Not even sure if this belongs in the Mala forum. If it doesn't please move with my apologies. I am running Mala 1.74. When I try to load up a Playstation iso through Mala through epsxe the game starts but won't display. All I get is horizontal banding across the screen. This is the same for PS2. I am using a Makvision tri-sync crt monitor (640x480) with an Arcade VGA. Games in Mame and Daphne work fine. Is there maybe a setting that is not checked off? I have selected:
External SPU Plugin 1.41
Moobys CD Image Drive 2.8
Pete's OpenGL 1.71
Any thoughts?
Thanks for any help.
Evan
Re: Epsxe won't diplay in Mala properly
« Reply #1 on: August 13, 2012, 09:46:18 pm »
Is it working outside of Mala?
Have you tried the command line settings in this thread?
http://forum.arcadecontrols.com/index.php/topic,93781.0.html
« Last Edit: August 13, 2012, 10:37:25 pm by harveybirdman »
EvanW
« Reply #2 on: August 13, 2012, 11:06:26 pm »
Does not work outside on MALA either. It finds the image fine and loads it. Just won't display it properly. I was looking in the configs for an option to maybe change the output resolution settings? My thinking was that maybe it's running at something outside of the monitors tri-sync settings? I get the same problem with MACH 3. Loads up fine and I can start to play it (well I can hear it playing), just can't see anything as the screen goes haywire with horizontal lines. I thought that buying an authentic CRT arcade monitor would display everything and give me that authentic arcade feel and look.
« Reply #3 on: August 13, 2012, 11:26:55 pm »
what's the lowest resolution your version of Pete's OpenGL will do?
EvanW
« Reply #4 on: August 14, 2012, 11:35:26 am »
Pete's OpenGL Driver 1.76 and Pete's OpenGL2 Driver 2.8 are the only options.
I actually just got it working. I must have been at it too late last night. In the 1.76 config options I set the default to "Nice" and changed the desktop resolution to 640x480 to match my monitors setting. Everything loads and works great now!
MACH 3 still does not display properly though. But the Nintendo, PS1, PS2 and the rest all finally load and display properly.
Thanks for the help!
