Author Topic: Direct3D Rendering Issues [RESOLVED]  (Read 3445 times)
tokyorock
  • Last login:June 07, 2013, 11:00:17 am
« on: August 12, 2012, 06:35:26 pm »
After resolving many issues with my computer, another error has appeared involving Direct3D Rendering. Every time I try to run a ROM, it is lagging or unresponsive. I have already updated my sound and video card drivers and installed the latest version of DirectX. What should I do now?
My Computer:
Windows XP Professional SP3
Intel Pentium 4 CPU 2.00GHz Processor
1GB RAM
ATI Rage XL 8MB PCI Video Card
CMI8738 PCI - 6CH - LX Sound Card
---------------------------EDIT-------------------------------
I found an ATI Rage 128 Pro 16MB AGP Video Card while searching through my computer graveyard, which runs games such as Pac-Man just fine, but games such as Spiderman still don't work properly and give me the Direct3D error message.
« Last Edit: August 20, 2012, 09:43:56 pm by tokyorock »
Re: Direct3D Rendering Issues
« Reply #1 on: August 12, 2012, 08:55:08 pm »
Are you using MameUI?  if so try going into game properties and selecting the "Videomode" of Direct Draw.
tokyorock
« Reply #2 on: August 12, 2012, 09:33:51 pm »
I am currently using MAME 0.146 and MaLa.
Is switching to MameUI the only option I have?
« Reply #3 on: August 12, 2012, 09:45:17 pm »
No not at all, just have to change the mame config
in the directory where you have mame there should be a config file.
Open in with notepad, scroll down to video options
there is something that says
Video                        d3d
change the d3d to ddraw save then launch a game and see if that helps.  If it does then you may need a different version of direct3d in order for it to work.
capsule
  • Last login:June 22, 2013, 12:05:13 pm
    • caps:arcade
« Reply #4 on: August 13, 2012, 05:02:18 am »
Mame's D3D needs a directx9 compatible card.
I tried different cards on the 1UP cab I want to sell...
- Integrated SIS chipset : no luck
- TNT2 : no luck
- GeForce4 MX440 : works like a charm
So you need to find a more recent card to use D3D mode. DDRAW will be too slow.
Finding a GeForce4 MX440 today is very easy and cheap.
tokyorock
« Reply #5 on: August 13, 2012, 04:52:15 pm »
My computer is a bit outdated, and it features three 5V 32 bit PCI slots and one 1.5V AGP slot.
Since the GeForce4 MX440 requires a 64 bit PCI slot to function, it will not work in my computer. However, because I do have an AGP slot, I will be able to get a video card fast enough to run MAME (probably 64MB or more) for only a slightly higher cost than the GeForce4 MX440.
No card in particular in mind, but a quick eBay search brings up lots of results.
capsule
    • caps:arcade
« Reply #6 on: August 13, 2012, 04:56:20 pm »
Nope, Geforce4 MX440 is AGP 8x (runs fine on slower AGP slots as well) so it should be fine for your computer, but yes, any similar AGP card could work.
tokyorock
« Reply #7 on: August 13, 2012, 06:20:21 pm »
I purchased a NVIDIA GeForce4 MX 440 on eBay for $9.80, and it works like a charm.
« Last Edit: August 20, 2012, 09:43:15 pm by tokyorock »
