Author Topic: MameWah Background image ??  (Read 3245 times)
Coffein
  • Last login:June 14, 2004, 08:15:41 am
« on: October 07, 2003, 01:59:59 pm »
Hi All
I have the latest MameWah release installed. It is up and running but the only thing i can
« Last Edit: October 07, 2003, 02:53:30 pm by Coffein »
Re:MameWah Background image ??
« Reply #1 on: October 07, 2003, 02:28:47 pm »
The background image needs to have the correct filename/path for it to work in MAMEWAH itself.
Read the Layouts.txt file in your \Layouts folder, it should explain all :)
Coffein
« Reply #2 on: October 07, 2003, 02:46:05 pm »
Hmmm not clear enough for me though  :)
I have a folder called D:\MAMEWAH\LAYOUTS\cab640x400 with the following files:
layout.lay
in the mamewah cfg i have these lines under ;misc
Layout Name = D:\MAMEWAH\LAYOUTS\cab640x400
Where should i put these setting in the layout.cfg  ???
/Coffein
« Last Edit: October 07, 2003, 02:53:07 pm by Coffein »
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #3 on: October 07, 2003, 02:51:28 pm »
I have a folder called D:\MAMEWAH\LAYOUTS\cab640*400 with the following files:
Interesting...
Windows doesn't allow you to have folders with "*" in them...
You may want to double check that...
I'm not a freak!...
Oh wait...
Yes I am...
Coffein
« Reply #4 on: October 07, 2003, 02:54:24 pm »
Ups i use x and not *
/Coffein
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #5 on: October 07, 2003, 03:53:51 pm »
I'm having the same problem...
I do like the new release though!!
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
« Reply #6 on: October 07, 2003, 07:33:33 pm »
Who wasn't paying attention to the last revision, lol  :D
I changed the system slightly with v0.96...I did include a revised Layouts.txt with the download, but here's the crucial part:
Backgound Images:
emu?-main.???      emulator specific main backgound image
main.???      general layout main backgound image
emu?-options.???   emulator specific options menu backgound image
options.???      general layout options menu backgound image
emu?-message.???   emulator specific message box backgound image
message.???      general layout message box backgound image
         (if none of the above exist, no background image will be used)
Coffein:  All you need do is remove the 'layout-' before the 'main.jpeg'.  Actually, you may have to change to .jpg rather than .jpeg - this should work too but I can't remember atm how I did it  :-[
dhansen
    • Arcade Stupidity
« Reply #7 on: October 08, 2003, 08:18:31 am »
Ahhhh!  I see!  Thanks Minwah!  All is well now....
Doug
Coffein
« Reply #8 on: October 08, 2003, 03:08:29 pm »
mmhhh still no luck after renaming the bakground file til main.jpg  ???
BTW: A great frontend, i am sure it works ok with the right user  :D
/Coffein
« Reply #9 on: October 08, 2003, 07:07:29 pm »
Email me your .lay / .jpg 's and I will try to see what the problem is :)
Coffein
« Reply #10 on: October 09, 2003, 03:41:04 pm »
Thanks alot MinWah for the latest update. It seems that it solves my problem with the background image.  :)
Greeting
/Coffein
RCadeControls
  • Last login:October 11, 2003, 12:01:23 pm
« Reply #11 on: October 11, 2003, 12:04:44 pm »
I am new to MameWAH and having similar troubles.
I have downloaded a number of the pre-made custom layouts and none of them work at all.
Not working = No background images or artwork displaying.
Do I have to go and rename every custom file if I want to use it?
The layout editor loads the files fine, but mamewah does not.
Other than the fact it does not work, this looks like a promising front end...
RCadeControls
« Reply #12 on: October 11, 2003, 12:26:00 pm »
 :-X :-X :-X :-X
Of course, now it does not work at all. Cannot change the layout at all no matter what name I make the dir.
MameWAH = Waste of time.
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #13 on: October 11, 2003, 03:29:05 pm »
:-X :-X :-X :-X
Wow, 2 posts and you're already ripping MameWAH?  MameWAH is about the best front end out there right now, and if you haven't noticed, MinWah spends a great deal of time here trying to help folks the best he can.
So RTFM, and then come back and ask some smart questions.....
« Reply #14 on: October 13, 2003, 08:30:04 am »
:-X :-X :-X :-X
You obviously did something wrong.  The fact that you can't change layout means that you haven't entered a valid layout.
Read Layouts.txt from whichever version download you are using, it explains all.  Alternatively, use MAME32, you might find it less of a 'waste of time' :P
« Last Edit: October 13, 2003, 08:31:01 am by Minwah »
