Author Topic: Cutting existing cabinet down to size?  (Read 2720 times)
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
« on: August 08, 2012, 05:30:44 pm »
Wondering if it's feasible to cut down a cabinet to make a slim cabinet
Cabinet I'm thinking of doing this to is a capcom big blue
Sent from my Xoom using Tapatalk
« Last Edit: August 08, 2012, 05:41:46 pm by ccmathome »
compute
  • Last login:February 26, 2018, 05:33:36 pm
Re: Cutting existing cabinet down to size?
« Reply #1 on: August 10, 2012, 03:18:47 pm »
Since most cabinets I see have a slope at the top, you're probably going to have to build an entirely new back and bottom plate.  So now you'll need to paint or laminate.
The only thing I would worry about is having balance.  The cab you're chopping may be front-heavy, so having a wider base keeps it from tipping forward.  Aside from that, I really can't think of any issues.  Make sure to install cross-braces before chopping, since much of the not-folding-on-itself comes from it being a square box.
I think I would build from scratch for something like this.  For a "slim" cabinet you may be able to get away with a design that utilizes only one 4x8 sheet of your choice material, and you won't have to deal with water damage or anything like that.
