Author Topic: tron stick  (Read 2042 times)
daruble
  • Last login:August 24, 2013, 06:23:58 pm
tron stick
« on: July 21, 2012, 06:33:25 pm »
Sorry for the noob question but. Can anyone tell me is their anyway to use a 49 way joystick for tron ???? I have the blue plastic housing for tron that mounts to the joystick. But if I use a 49 way instead I can use it for more game plus tron and others. I was reading another post where the person stated that they wish they had a 49 way controller.
Sorry don't know much about the difference between a 8 way and a 49 way. Can I get a tutorial on differences or somthing. :dunno :banghead:
Dave Ruble
Gray_Area
  • -Banned-
  • -Banned-
Re: tron stick
« Reply #1 on: July 22, 2012, 02:09:26 am »
Old question. Answer is, yes. Question is, would you want to?
Answer: you don't know. You need to go look up these controls to get an understanding.
-Banned-
  • Last login:Today at 11:07:46 am
Re: tron stick
« Reply #2 on: July 22, 2012, 10:35:05 am »
Welcome to the forums, Dave.
An 8-way stick has 4 switches - Up, Down, Right, and Left. If you press the joystick in the 45 degree direction, you activate both the Right and Up switches.
To picture how a 49-way stick works, picture a 7x7 grid.  When the stick is centered x=4, y=4.  (* on the diagram) This allows a slow, medium, or fast in each direction.  If you were to push a little to the right and all the way up, you would get x=5, y=1 (# on the diagram)
_1  2  3  4  5  6  7
1                #
2
3
4           *
5
6
7
More on 49-way joysticks in the wiki.
A Tron stick is an 8-way with a special restrictor plate that makes it harder to hit the diagonals. (less zig-zagging on the light cycle stage)  More on it in the wiki.
A less expensive (and shallower to mount) option is to use a magnetic triggerstick hack like Tony shows here or the Import Flight Stick from Paradise Arcade (Ultimarc carries them, too) for the 8-way parts of Tron and switch to a dedicated 4-way wired in parallel for the light cycle stage.
If you decide to do autoswitching 4 to 8 way joysticks, Le Chuck has got in-game switching for Tron working here.
Lots of good stuff to read on the wiki -- it will give you the background to understand what people are talking about in the forums and ask "non-noob" questions.   ;D
daruble
Re: tron stick
« Reply #3 on: July 25, 2012, 10:36:04 pm »
Thanks for answering the Noob questions with such detail. I will read all the links and see if I can figure the arcade controls out. Thanks again for making me feel welcome to your community.
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
Re: tron stick
« Reply #4 on: July 25, 2012, 11:29:03 pm »
The guys from here know there stuff  :notworthy:! They have given me all the help I could ever need! Dont feel bad, I have had my share of noob questions too! Welcome to the community!  :cheers:
