Author Topic: Ivan 4x4 360 degree wheels > MAME  (Read 1708 times)
MartinJames
  • Last login:March 28, 2021, 10:10:33 am
« on: July 19, 2012, 04:11:02 pm »
Well I've email Gremlin Solutions twice now with no reply.
I have an Ivan 4x4 that I want to mame up, but unsure which ultimarc kit I need as the wheels are 360 and the pedals are digital. Any help?
Ta
Re: Ivan 4x4 360 degree wheels > MAME
« Reply #1 on: July 19, 2012, 04:33:55 pm »
The U-HID can handle both the steering wheel and the pedal, as well as buttons and LED outputs.
http://www.u-hid.com/home/index.php
If you're not worried about adding any new controls, you might get away with using the U-HID nano which is cheaper but only has 8 inputs.
If you want to cheap out, you can hack the steering to an old rollerball mouse and the pedal to a gameport.  :P
« Reply #2 on: July 19, 2012, 04:39:20 pm »
I'm pretty sure those pedals were analogue (potentiometer).
If they're just a switch, you could get away with just using a trackball/spinner interface (or mouse hack).
It will show up as a mouse and pedal, start, & coin could be wired as mouse buttons.
http://groovygamegear.com/webstore/index.php?main_page=index&cPath=76_85
paigeoliver
  • Awesome face!
« Reply #3 on: July 19, 2012, 10:01:40 pm »
Would the U-HID nano be enough to do a pole position cockpit? 360 wheel, 2 analog pedals, and 3 "buttons".
« Reply #4 on: July 19, 2012, 11:33:24 pm »
I don't think, but you could check with Andy about some of these workarounds:
The analogue inputs sense voltage, so if you used an external 5v power source, you'd only need one pin per pedal.
That looks possible on pg 11 of the manual (the nano has the same functionality, just fewer pins):
http://www.u-hid.com/u-config/u-hid%20Manual.pdf
3 pins + ground for buttons leaves only 2 pins for the optical encoder.
This is where I think we run out of room.
If the optical encoder can use power from an external source, that would just get you there.
But judging from the examples, I'm guessing this isn't possible.
I'm sure Andy could answer it in a heartbeat if you emailed him.
