Author Topic: HUGE font in MameWah  (Read 1101 times)
Hamselv
  • Last login:May 16, 2010, 08:08:44 am
« on: October 05, 2003, 05:06:58 pm »
Hi there,
I have just begun tinkering with Mamewah, but for some reason I the 'main' font is absolutely huge.  ???
Hence, when I press '2' to change my Options, I can only see the first 3-4 letters of the top line of the Options box.
Also, the game list only shows ~6 letters of each game title... there's simply not room for more.
I run Mamewah at 1024x768 currently.
Has anybody seen this problem and knows a fix for it?
TalkingOctopus
    • My Arcade
Re:HUGE font in MameWah
« Reply #1 on: October 05, 2003, 07:57:18 pm »
You can change the font size in the layout editor.
Jaxxon
  • Last login:April 15, 2010, 06:22:36 am
« Reply #2 on: October 06, 2003, 12:06:58 am »
I also had this error when I ran Mamewah for the first time on my german Version of XP.
Try to set your system settings to US-English, reinstall Mamewah and you should be fine.
That did the trick for me...
You might want to have a look at this thread http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=11781
Regards,
Jaxxon
« Last Edit: October 06, 2003, 12:10:15 am by Jaxxon »
« Reply #3 on: October 06, 2003, 04:59:52 am »
As Jaxxon says, try setting your language to English.  Also, you will probably have to set your Decimal Symbol to '.' (rather than ',').
You should not have to re-install tho...
Hamselv
« Reply #4 on: October 06, 2003, 03:01:43 pm »
Thanks a lot!
That did the trick :)
