Author Topic: Autorun problems with MAME/mgalaxy –Solved  (Read 2911 times)
8-bit_Frost
  • Last login:July 09, 2012, 05:40:46 pm
« on: July 06, 2012, 12:37:21 pm »
Ok, so currently on the computer running MAME I have it set to auto-start everything from boot up.
There’s a hidden power button in the coin reject slot and after pressing it the system boots, the windows
login screen is mostly hidden, windows logs in automatically, and the start menu bar is hidden with a
loading screen where the normal desktop would be.
After this I have the computer set-up to auto run the mgalaxy.exe which starts properly: music starts playing,
full list of available roms can be seen. The problem however is when you go to actually launch a game;
instead of running I get an error from mame saying that the files .cpu .u and pron .u (long list) cannot be
found then finally saying that  MAME: error required files are missing the game cannot be run.
Now the weird thing is this only occurs from auto running it. When manually starting the .exe from either explorer
or a short cut  mgalaxy will start up fine and the games will run fine just the same.
So I can’t figure out what’s wrong, to me starting the front end yourself or via an auto run program should
make no difference, I’ve even tried putting a 60 second delay on the auto run, but to no avail :/
Any ideas?
« Last Edit: July 09, 2012, 04:39:08 pm by 8-bit_Frost »
8-bit_Frost
Re: Autorun problems with MAME/mgalaxy –Help
« Reply #1 on: July 09, 2012, 04:38:49 pm »
Nvm,solved it myself, the problem had to do with how the auto-run procedure was being handled in the registry. Which while normally this
wouldn't make a difference I think it is related to similar problems of mgalaxy being finicky when launched from quick-start icons.
