Author Topic: Hantarex MTC 9000 Problem  (Read 2330 times)
keithgeo
  • Last login:July 12, 2012, 01:44:44 pm
« on: July 03, 2012, 11:23:54 am »
Hey guys, total noob to all this so hoping you might help out.
I picked up a cab a few weeks back but the monitor doesnt work.
I get sound etc when its switched on but nothing on the screen at all.
Its a Hantarex MTC 9000 and i think its 25inchs.
Now, this is my first arcade cab with a CRT in it.  I have a Mame cab i built myself.
I know nothing about this other than reading up on how to discharge a crt (Which i have never done)
Is there any way to narrow down what the issue is?  should i see a light somewhere even on the CRT to at least tell me its getting power?
Thanks a lot!
Edit; I should say im in Europe, Ireland.
I know its a bad first post! Ive been reading the site for ages and it was a great resources as I built my Mame cab. so thanks for that and future help!
« Last Edit: July 03, 2012, 11:31:46 am by keithgeo »
ed12
Re: Hantarex MTC 9000 Problem
« Reply #1 on: July 03, 2012, 04:16:17 pm »
hi
and yes
hook everything back up as normal
power unit up
and see if u can see a orange glow at the neck of the tube
this will be the heaters of the tube
this is the first step
ed
keithgeo
« Reply #2 on: July 03, 2012, 04:48:31 pm »
Hey, thanks for the reply.  Do i need to leave it on long to see the glow?
I turned it on there and cant see any glow at all to be honest.  Am i looking at the glass part on the end for the glow?
When i power on the cab, it makes a noise like the screen is switching on, plus theres a slight buzz noise that you would hear from a powered on crt.
But nothing at all on screen, not even a flicker.  Thanks again.
ed12
« Reply #3 on: July 03, 2012, 04:53:34 pm »
hi
yes if is all hooked up
u should see a glow at the neck of the tube
if not then we start
let me ask u a q
do u have a multi meter ? and if so can u use it propley ?
the reason i am asking is because there is a few possiable's here
and both require a meter
ed
keithgeo
« Reply #4 on: July 03, 2012, 04:57:07 pm »
Hey,
I dont have a multimetre, I can get my hands on one though.
I also dont know how to use it either haha, but im a quick learner!  In general i know what it does, reads power off things by touching with the end etc.
If i get a hold of one and come back here would you be able to describe what to do to track down the problem, it would be greatly appreciated.
ed12
« Reply #5 on: July 03, 2012, 07:53:45 pm »
hi
i will try
ed
keithgeo
« Reply #6 on: July 04, 2012, 03:06:02 am »
Thank you, i will reply back once i have the multimetre.  8)
shyguy2457
  • Last login:September 24, 2012, 09:39:05 pm
« Reply #7 on: September 24, 2012, 07:57:12 pm »
I am also having an issue with my MTC it is the 9110. I do have the glow in the neck of the tube. I am stuck at this point. When I power the system on thew screen does flash white for a split second. I know it is getting about 20000 volts fromt he flyback. I am not new to working on these it has just been a while since I got out of doing it. any suggestions on how to repair? Thanks in advance.
ed12
« Reply #8 on: September 24, 2012, 11:11:17 pm »
hi
ok fast q here
as i went over my libary of monitor pdf's
i could not find the the 9010?
is it tri-sync ?
if so i can walk u through it faster
if it is vga/cga olny :ie: signal-sync
that is fine
i just need to be clear before i answer u
ed
