Author Topic: Pattern routing  (Read 2380 times)
photon
  • Last login:October 16, 2015, 06:20:53 pm
Pattern routing
« on: June 24, 2012, 04:24:24 pm »
I'm just getting started on 3 identical bartops. Am I better off doing the pattern routing by hand or mounting the router in a table? I have a tablesaw extension that has a basic router mount that I've only ever used with a fence. Also the same question in regards to cutting the slots for the t-molding. The sides will be 5/8 or 3/4 MDF.
Thanks.
selfie
Re: Pattern routing
« Reply #1 on: June 24, 2012, 06:02:13 pm »
Which is the most stable for your workpiece? If the saw bench has a large enough table top to support a large percentage of the pattern I would be doing it this was. If the router fixture in the saw is only small you will have more luck with the router in hand.
yaksplat
    • Random Projects
Re: Pattern routing
« Reply #2 on: June 25, 2012, 07:04:16 am »
Any routing done on the outside of a piece is easier done with a router table.  Any button and joystick holes should be routed by hand.
I just did this over the weekend for a customer, but i didn't have my router table set up, everything was done by hand.  4 panels with the same outer edge and a row of button holes along the top edge.
I then created plexiglass tops using these panels as templates.  They might be a little hard to see, but they're there.
http://yaksplat.wordpress.com
