Author Topic: CP / Plexi /T-Mold combo  (Read 2045 times)
Tonyjambo
« on: June 22, 2012, 11:36:15 pm »
Hi all - my first post and im just in the planning stages for my first cab.
I'm planning on a pretty simple Streetfighter+trackball layout for my CP but stumbling on such simple things as :
Whats the best combination of thickness of CP (MDF) , plexi and tmould that makes a sturdy well put together panel ?  Do i even need to add the plexi if i get a laminate from somewhere like gameongrafix ?
thanks in advance - many more posts to follow im sure
shponglefan
Re: CP / Plexi /T-Mold combo
« Reply #1 on: June 23, 2012, 12:15:06 am »
I've used 1/2-inch MDF, 1/8 inch plexi and 5/8 inch T-molding.  Alternatively, you could use 5/8 inch MDF or 1/4 inch plexi, and then use 3/4 inch T-molding.  That would give you more options in the T-molding department.
« Last Edit: June 23, 2012, 12:17:32 am by shponglefan »
Tonyjambo
« Reply #2 on: June 23, 2012, 08:37:13 am »
yeah - i was looking at the 1/2 mdf 1/4 plexi but i figured that plexi might be too thick
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #3 on: June 23, 2012, 09:03:58 am »
You could also go with 1/2 inch MDF with 1/8 inch board and 1/8 inch plexi.  I did this to provide a good surface for the artwork and to allow for easy swapping of parts later.
gamepimp
  • Last login:April 06, 2025, 08:48:37 pm
« Reply #4 on: June 23, 2012, 10:11:16 am »
I'm redoing my CP and I'm going to try 3/4" mdf with 1/8" plexiglas and 3/4" t-molding. I'm going to bevel the bottom edge of the CP with a 45 degree router bit so that it takes off 1/8" from the overall thickness. That way the thickness of the edge of the CP will appear to be 3/4" and will match the molding.
I did see a guy on eBay selling 1" t-molding. I contemplated that before I decided on the beveling approach. But then I thought it might look odd being so thick...
shponglefan
« Reply #5 on: June 23, 2012, 10:42:10 am »
It would be pretty thick.  IMHO, 1/8 inch plexi is perfect to work with.  Not to mention, cheaper.
Tonyjambo
« Reply #6 on: June 26, 2012, 02:03:10 pm »
Thanks guys - i'm going to go 3/4" mdf and 1/8 plexi with a bevel on the bottom to take the edge down to 5/8 then cut the T-Mould slot 1/8 north of center , I think it should look pretty decent - more concerned with the Top of the CP than the bottom.
@Dawgz - i like that approach just because it means no routing out for the trackball :)  is the happ trackball mount actually 1/8' by any chance or did you ahve to shim it ?  it does give you a nice clean surface as well - tempting :)
Dawgz Rule
« Reply #7 on: June 26, 2012, 06:54:44 pm »
Shimmed it with some small washers.
Dawgz Rule
« Reply #8 on: June 26, 2012, 06:56:24 pm »
The 1/8 inch plexi was the perfect height for the lip of the trackball too.
spkywlnt73
  • Last login:February 18, 2020, 08:15:24 pm
« Reply #9 on: June 26, 2012, 07:33:22 pm »
I was able to find 5/8 mdf but it was speical order. So I have 5/8 mdf and 1/8 inch plexi, 3/4 t-molding.
