Author Topic: MAME command line for DirectDraw?  (Read 10516 times)
c0dehunter
  • Last login:July 07, 2014, 04:07:45 am
« on: June 17, 2012, 03:23:07 am »
Hello all,
What is the command line to run MAME in DirectDraw (instead of Direct3D, since I am using a real arcade monitor and Soft 15Khz).
And how can I make this change permanent? In the mame.ini?
I am using HyperSpin, with my Commodore 1084S-D1 monitor, and the games look filtered. When I used MAMEUI, I can disable D3D and use DirectDraw instead. How can I do this for regular MAME?
Calamity
  • Last login:Today at 05:01:03 pm
  • Quote me with care
Re: MAME command line for DirectDraw?
« Reply #1 on: June 17, 2012, 04:53:42 am »
The option is -video ddraw, so:
mame romname -video ddraw
you should remove hardware stretching too:
mame romname -video ddraw -nohwstretch
To make any change permanent edit mame.ini and modify the required options. If you don't have a mame.ini file yet create it like this:
mame -cc
Inside it you'll have:
video d3d (-> change this to ddraw)
hwstretch 1 (-> change 1 to 0)
Notice that the command line option -nohwstretch is equivalent to "hwstretch 0" in mame.ini, and so on.
Steps to create a log:
c0dehunter
« Reply #2 on: June 17, 2012, 01:23:00 pm »
Thanks! You are the best!
