Author Topic: I have SERIOUSLY messed up (I think)  (Read 4399 times)
poooookah78
  • Last login:June 15, 2012, 05:12:58 pm
« on: June 14, 2012, 07:08:18 pm »
Hi everyone,
I'm really kicking myself right now because I think I've done something so stupid and horrible.
I have been planning a cab build for over a year and finally got to a place where I could make one.  I bought all the parts/tools, etc and began work.  I made the first side, then the second, really taking my time and doing a great job.  I then routed to edges for the T Molding.  I'm using arcadecab.com as a reference for the plans and for whatever reason, had it in my head that routing the sides for a 3/4" t molding edge, I would need a 1/4" slotter.  I have slotted my entire cab with 1/4" a slotter bit.
My questions are:
a.  Am I screwed?
b.  Does 1/4 slotted 3/4 t molding exist and where?
THANKS GUYS!!
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
Re: I have SERIOUSLY messed up (I think)
« Reply #1 on: June 15, 2012, 07:24:33 am »
Time for bondo.
phyrosis
  • Last login:June 20, 2012, 06:54:07 pm
« Reply #2 on: June 15, 2012, 09:03:54 am »
if you are using MDF i would make a MDF sawdust slurry with a construction adhesive, slather it in the groove, let it dry for two days and start all over...
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #3 on: June 15, 2012, 09:31:21 am »
Time for bondo.
+1
Throw some bondo in there, let it set, and re-route the slot.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: June 15, 2012, 10:13:03 am »
You aren't screwed but you do have a challenge now.  I think you'd be the best off if you just took another 2 inches off all around your cab and then re-routed the T-Molding.  If you aren't prepared to make it smaller then you'd have to use Bondo or a filler concoction and after it sets you would then re-route it.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Re: Re: I have SERIOUSLY messed up (I think)
« Reply #5 on: June 15, 2012, 12:06:26 pm »
Would be less trouble to recut the sides and do it right.
I'm with this train of thought. Your still at the beginning if your just cutting the sides. Start over and do it properly. Use the wood that you messed up for other parts of the cab. Bottom top, control panel, whatever.
Sent from my Desire HD
TopJimmyCooks
« Reply #6 on: June 15, 2012, 12:10:48 pm »
If your damaged sides are how you like them in terms of shape, it would be quite easy to just use them as a template to pattern rout the new sides.  got a 1" flush trim bit for your router?  if you do it precut to near the line so you're only routing off 1/4" or so wood at a time.
poooookah78
« Reply #7 on: June 15, 2012, 04:32:33 pm »
Hey,
Thanks for the replies everyone!  I literally just got done routing the edges down to the non routed bit, then cloned it w/ a flush 1" bit.  Now to buy yet ANOTHER bit (1/16 slot cutters, all of which are like 20 bucks w/ shipping  :(  ).
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« Reply #8 on: June 19, 2012, 01:16:11 pm »
Hey,
either that or $9.99 with free shipping
http://www.ebay.com/itm/Porter-Cable-1-16-Slot-Cutter-w-1-2-Shank-Arbor-Router-/140774054078?pt=Routers_Bits&hash=item20c6c998be
Mysterioii
  • Last login:August 31, 2018, 11:44:34 am
« Reply #9 on: June 19, 2012, 02:31:32 pm »
Nice price, not a buy-it-now though.
I might take a stab at it though.   ;D
