Author Topic: Playing higher resolution vertical games on WG25K7191  (Read 1713 times)
RyuHayabusa78
  • Last login:October 01, 2012, 10:23:03 pm
« on: June 14, 2012, 04:01:51 pm »
Ok, so I'm playing some vertical games on my WG25K7191 monitor and while some look great, like Galaga, Pac Man, Donkey Kong, others like Donpachi, E.S.P.Rade, 1945III don't. Games like Donpachi run at a higher resolution than those older Namco games and no matter what resolution I run them at, the top and bottom are chopped off. I've tried 352x288, 384x288, 512x288, 352x264, etc. and nothing works. The only way to get these games to fit on my monitor is to check the stretch to fit option in Mame32, which makes the game display in a square shape rather than the usual vertical rectangle shape and makes things look less than sharp. I'm using an ArcadeVGA card. Any suggestions?
Re: Playing higher resolution vertical games on WG25K7191
« Reply #1 on: June 18, 2012, 12:34:02 pm »
turn your monitor 90 degrees
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #2 on: June 18, 2012, 06:04:37 pm »
Although it isn't a perfect solution, you can always adjust the vertical (horizontal) stretch within the mame settings to compensate a little bit.  I like this better than the stretch to fit option.
ahofle
    • Arcade Ambience Project
« Reply #3 on: June 19, 2012, 12:32:32 am »
Try running them at 640x480 with hardware stretch on.  You simply aren't going to be able to run those games with pixel accuracy on a CGA monitor with the wrong orientation.
