Author Topic: Any feedback comparing an X-Arcade Trackball versus other Trackballs?  (Read 4639 times)
Arimack
  • Last login:July 22, 2024, 08:02:29 pm
  • OFNQ - Old Farts Never Quit -
    • forum.arcadecontrols.com/index.php/topic,157605.0.html
The X-Arcade Trackball looks like the best priced arcade trackball on the market assuming you are not going bargain basement with one of the $25 MAME trackball (I bought one of these MAME ones while I test out control panel layouts but will likely eBay it after I have set my panel layout.)  I would love to hear the consensus on the X-Arcade Trackball.
So, how does the $59 X-Arcade compare to the other options out there?
The advantage I see right off the bat is that the X-Arcade includes the mounting hardware, encoder and mouse button wiring as standard while most of the rest (Paradise, Groovy, etc) see to have these as extras boosting up the cost.  But how is the feel of the X-Arcade trackball?  Any advice would be appreciated.
X-Arcade Trackball
http://www.xgaming.com/store/arcade-parts-and-accessories/product/x-arcade-trackball-assembly/
Cynicaster
X-Arcade Trackball
My brother has a tank stick and the trackball was fine when it still worked.  It no longer registers up/down movement (probably bad encoder board or something).
mytymaus007
if your on a budget it gets the job done! But if you want precission all the other arcade trackballs are much more accurate and spin more freely, If im not mistaken i dont think the Xarcade is rolling on bearings and the other trackaball are. im not 100% but i think thats correct anyone have access to the xarcade trackball insides
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
I actually have two X-Arcade trackballs mounted to my CP and I've been very happy with them.
No issues at all after years of use.  They aren't heavy duty for commercial use, and they may or may not hold up from an army of kids pounding on them all the time, but they should be just fine for home hobby use and friendly games.
I took one apart years ago and I recall it looked like an old style mechanical ball mouse.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
Arimack
@mytymaus007 -Short of blowing $180 on a HAPP, which trackball setup would you recommend?
@Afterburner -Thanks for the info.  Was the mounting straight forward on them?
mytymaus007
Check out this deal never saw one so cheap maybe because its not usb but dont matter
http://www.ebay.com/itm/NEW-3-IMPERIAL-Arcade-Trackball-w-mounting-plate-game-buttons-/120821157716?pt=LH_DefaultDomain_0&hash=item1c21808f54
or the HAPP is awsome to but its more money but it lights up if you care
http://www.ebay.com/itm/HAPP-CONTROLS-3-USB-PS2-TRACKBALL-ARCADE-WKS-W-MAME-/380441654266?pt=LH_DefaultDomain_0&hash=item589416f3fa
Arimack
@Afterburner -sidebar- I'm curious, what games do you need 2 trackballs for?  I can only think of 1 or 2 from back in the day.
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
I've got to throw my 2 cents in here also.  When I learned about MAME and I first decided to build an arcade cabinet, I wanted to keep it easy but a trackball for Golden Tee was a must.  About 10-12 years ago my buddies and I hung out at a sports bar that always had a GT machine and we played it often and we played it hard!!!  I bought the tankstick mainly just to play Golden Tee and when my buddies come over to play, we are not easy on it at all.  I've had it for over a year now and it has never given a problem. I took it apart once to clean the rollers (very easy to do) and that's it.  The rollers are in fact in metal ball bearings.  You can adjust how freely the trackball spins by how tight you mount it to the CP.  I have mine spinning very freely and it reminds me of my younger bar room days playing GT at my favorite sports bar, which has since closed down...... :cry:   :cry:
Afterburner
The X-arcade trackball mounts are very straightforward.  Just four bolts.  I used ones with countersunk heads so they don't show.
I have two trackballs so I can play Two player lightgun games or two person racing like SuperSprint.
I'm considering going to two Aimtraks though.
Arimack
The conversion's really that easy, PBJ?  I knew the old arcade ones were tough but you have had good luck with them being mechanically sound when buying them used off ebay?  From your comment, I am tempted to try and recondition a used one and convert it over.  I'll search the forum for the PS2 conversion.  Any possibility to make it USB or is it too complicated to be worthwhile?
mytymaus007
Re: Any feedback comparing an X-Arcade Trackball versus other Trackballs?
« Reply #10 on: June 11, 2012, 06:34:52 pm »
to make it usb u need to get an optipac
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
« Reply #11 on: June 11, 2012, 08:15:01 pm »
I got my Happ from ebay for $14 shipped.  It came in near brand new condition.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #12 on: June 12, 2012, 09:52:18 am »
I've done a few of the imperial trackballs for builds throughout the years and I really like them.
Cynicaster
« Reply #13 on: June 12, 2012, 05:36:01 pm »
Solder it to a $5 PS/2 mouse and you're good to go.  It's so easy and cheap I've given a few away and have a couple sitting in the junk pile.
That's a very tempting solution, but is there a chance it would be plagued by that "back spin" problem I've heard about that happens when you spin the ball too fast?
Arimack
« Reply #14 on: June 18, 2012, 08:28:01 am »
Well, serves me right for not referencing Saint's book :banghead:.  Was reading over the weekend and he covers the X-Arcade Trackball in the book.  It is a modified Bentson Imperial trackball.
