Author Topic: WTB Donkey Kong Wiring Harness (MO/USA  (Read 3644 times)
iSpaz
  • Last login:July 13, 2012, 01:49:47 pm
  • Stay Crunchy
« on: May 27, 2012, 10:43:01 am »
I am looking for an original DK wiring harness to purchase.  Please PM me if you might have something that could help me out
Every Pixel Counts!
ed12
Re: WTB Donkey Kong Wiring Harness (MO/USA
« Reply #1 on: May 27, 2012, 11:01:06 am »
hi
iSpaz
i need to ask this question
why do u want to buy a complete harness?
ed
iSpaz
  • Stay Crunchy
« Reply #2 on: May 27, 2012, 02:23:43 pm »
I basically need the connectors.  And I think it would also be a good reference to have around when I wire it up myself.  I have an original board
Every Pixel Counts!
ed12
« Reply #3 on: May 27, 2012, 02:46:48 pm »
hi
oringal donkeykong and pac-man are the same serie's board
 22 pin's on 1 side 22 on the other
if u want a pin out ring me up
and or boardjunkie
ed
iSpaz
  • Stay Crunchy
« Reply #4 on: May 27, 2012, 04:23:07 pm »
The connections I am needing to make are
9pin CPU Harness Connector
17pin Junction Harness Connector
7pin SOU Harness Connector
10pin CLK Harness Connector
Most of these run from the original boards to either the power supply, control panel, or monitor.  I need the correct connectors to plug into the original board.  I have no idea if I could just go out and buy some new connectors that would fit the original board or not.
Every Pixel Counts!
ed12
« Reply #5 on: May 27, 2012, 08:13:30 pm »
hi
they were made in japan
do not use the knock off's
myabe boardjunkie could chime in here
to help u ?
if not i will chk my stock
ed
iSpaz
  • Stay Crunchy
« Reply #6 on: May 27, 2012, 10:36:14 pm »
that would be greatly appreciated Ed.  And thanks again for helping me out with all of this :)
Every Pixel Counts!
ed12
« Reply #7 on: May 27, 2012, 10:50:40 pm »
hi
np
i know i have 1 around here
it's from a cocktail
is your's cocktail or stand-up ?
ed
iSpaz
  • Stay Crunchy
« Reply #8 on: May 27, 2012, 11:24:21 pm »
Ed,
  Mine is a TKG3-06 /  which I am led to believe it is a 4 board cocktail table version.  Correct me if I'm wrong
Every Pixel Counts!
ed12
« Reply #9 on: May 28, 2012, 12:43:39 am »
hi
do me a fav post a pic. please
i can do u better that way
thk's in advance
ed
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #10 on: May 28, 2012, 07:39:29 am »
Check in with Dokert over on KLOV and see if he has any of his fine repro harnesses left.
Working: Not Enough
Projects: Too Many
Progress: None
iSpaz
  • Stay Crunchy
« Reply #11 on: May 28, 2012, 10:54:45 am »
Cheffo,  I have not been approved over on the KLOV forums.  I have tried to get several members to recommend me, but it has not seemed to work.  I am still on a restricted account.
and Ed, I will upload a picture in just a minute.
Every Pixel Counts!
iSpaz
  • Stay Crunchy
« Reply #12 on: May 28, 2012, 11:04:59 am »
this first picture is of a 5 pin and a 9 pin connection I will need to make.
This second one shows the 12 pin and 17 pin connection I will need
And here are a few pictures of my board set
Every Pixel Counts!
ed12
« Reply #13 on: May 28, 2012, 12:10:54 pm »
hi
www.molex.com
there a starnded header
ed
iSpaz
  • Stay Crunchy
« Reply #14 on: May 28, 2012, 01:50:51 pm »
holy cow that website has tons of options... now I need to figure out which connection will fit properly.
Every Pixel Counts!
ed12
« Reply #15 on: May 28, 2012, 02:13:20 pm »
hi
a micaguage come's in handey right about now
as size's are quoted in . inch's,if u go to the .ca site it is in metric
u take holder size width-length and pin count + the size of pin
ie 14guage/12/16/18 etc
and from what i see 18 guage is in order
if boardjunkie would chime in the nick could tell u better
ed
Franco B
« Reply #16 on: May 28, 2012, 02:19:29 pm »
If they are Molex then I imagine you want to be looking at the wire to board connectors [here]
You can use the categories on the LH side of the screen to refine and narrow your search. I would start but measuring the pitch and select the applicable one. Then select the amount of circuits (pins) and you should hopefully be able to find what you are looking for from those results.
iSpaz
  • Stay Crunchy
« Reply #17 on: May 28, 2012, 02:26:14 pm »
yay I agree... I wish I had a gauge like that so I could figure out the specifics :(
this is about as good as I can do for measuring....
Dont know if that will help or not... but I still have my fingers crossed lol
Every Pixel Counts!
iSpaz
  • Stay Crunchy
« Reply #18 on: May 28, 2012, 02:31:28 pm »
wire-to-board / crimp housing / female / 1 rows /
thats as far as I have refined my search so far
Every Pixel Counts!
CheffoJeffo
« Reply #19 on: May 28, 2012, 02:36:22 pm »
PM me with your account info over there and promise not to be a spaz and I will vouch for you!
Working: Not Enough
Projects: Too Many
Progress: None
iSpaz
  • Stay Crunchy
« Reply #20 on: May 28, 2012, 02:41:35 pm »
PM'd  ;D
Thanks Cheffo.  Greatly appreciated
Every Pixel Counts!
ed12
« Reply #21 on: May 28, 2012, 02:45:52 pm »
hi
thk's CheffoJeffo
that show's a great ammoumt of help for the nick
side note here your pitch is now the olny thing u need answered
u have the rest of the data
ed
iSpaz
  • Stay Crunchy
« Reply #22 on: May 28, 2012, 02:52:42 pm »
hi
thk's CheffoJeffo
ed
I measured the small black plastic gap in between each socket on the female housing and came up with 1mm  Im guessing thats my pitch
Every Pixel Counts!
iSpaz
  • Stay Crunchy
« Reply #23 on: May 28, 2012, 03:03:50 pm »
Every Pixel Counts!
ed12
« Reply #24 on: May 28, 2012, 03:05:45 pm »
hi
thats the pitch and size
u are well on your way
ed
Franco B
« Reply #25 on: May 28, 2012, 03:39:21 pm »
No, that isn't the pitch. The pitch is the distance between the center of each pin. From your photos above it looks to be either 2.5mm or 2.54mm (0.100").
That brings us down to about 5000 products  ;D
I'll have a look and see if I can find them for you.
Before I spend ages looking, are you sure the manufacturer is Molex, ed12?
iSpaz
  • Stay Crunchy
« Reply #26 on: May 28, 2012, 03:50:12 pm »
AGREED^ I was looking at the options and diagrams for the 1mm and it was wrong.  So I remeasured and it was either 2.5 or 2.54....hard to tell with a ruler.
I was able to set up an account and order a few samples of most of what I needed.  (your suppose to have a business to even have an account with MOLEX.)
So hopefully I am able to even get the samples.... time will tell
Every Pixel Counts!
Franco B
« Reply #27 on: May 28, 2012, 03:56:35 pm »
I had a look through all of the 2.5mm and 2.54 housings with 17 and 15 circuits but sadly couldn't find anything that looked similar to yours.
I think your best bet would be to speak to Dokert. If he can't supply you with a harness then I imagine he would at least be able to tell you what connectors they are.
ed12
« Reply #28 on: May 28, 2012, 04:34:33 pm »
hi
Franco B
yes i very sure
i also use a company out of canada
if need i link
ed
iSpaz
  • Stay Crunchy
« Reply #29 on: May 28, 2012, 07:21:06 pm »
thanks Franco and Ed... maybe someone will know for sure sooner or later :P
Every Pixel Counts!
