Author Topic: Microswitch problem  (Read 1150 times)
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
Microswitch problem
« on: October 01, 2003, 10:22:18 pm »
I discussed this in the software forum, but since the solution was so odd, I thought I'd report it here FYI.
I was getting double key presses using an IPAC control panel that I had hooked up to a new XP computer.  At first I thought it was a usb driver problem, then an ipac configuration problem, then a wiring short.  Turns out the problem was that many of my microswitches decided to go bad at the same time.
What's odd is that all the switches were new last winter, and have seen only moderate use.
Oh well... it's fixed now.   ;D
Hopefully this will help others from going through all the same aggravating steps...
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
Apollo
    • Eight Bells
Re:Microswitch problem
« Reply #1 on: October 01, 2003, 11:45:30 pm »
That's pretty much impossible, I think you may have accidently fixed the problem while you were changing the microswitches. Like a short or something else? Microswitches built for millions of cycles don't all " go bad" at the same time.
Smittydc
  • because its fun!
« Reply #2 on: October 02, 2003, 12:07:30 am »
Nope, I isolated the wiring and swapped them in and out to be sure.  Definitely the switches.  They didn't "all" go bad -- some were better than the others with the problem only occuring sporadically, and others were fine.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: October 02, 2003, 05:10:12 am »
Spill some beer soda on the switches?  ;)
Robin
Knowledge is Power
cdbrown
  • Bowowow
« Reply #4 on: October 02, 2003, 05:56:43 am »
Perhaps you got a bad batch that slipped through the quality control.  Good to hear you got it sorted though.
Cheers
-cdbrown
