Author Topic: back to back 2 player bartop  (Read 10426 times)
jahilton2002
  • Last login:January 17, 2026, 05:34:53 pm
« on: May 14, 2012, 08:21:26 am »
The plan is two have a 2player bartop with each player having there own screen and cp.........
think two bartops back to back.....
now we have decided that we are going to build one..... but when we place two bartops back to back.... the top kinda looks odd..... anybody have any ideas?
Los Abrazos Rotos
Re: back to back 2 player bartop
« Reply #1 on: May 14, 2012, 08:57:00 am »
What do you mean by odd?  Just too bulky?
« Reply #2 on: May 14, 2012, 09:02:27 am »
Side by side angled (like the Beast)? For back to back, it would probably have to be sitting on a wide bar or narrow table.
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« Reply #3 on: May 14, 2012, 09:55:21 am »
You may need to provide a picture or some type of illustration.
jahilton2002
« Reply #4 on: May 14, 2012, 10:08:07 am »
Something kinda like this: (sorry fast mod in paint  ;D)
GregD
    • Arcade Nebula
« Reply #5 on: May 14, 2012, 10:09:22 am »
You may need to provide a picture or some type of illustration.  By the way, I just took a look at your website and the level of detail put into that Space Invaders cabinet is truly impressive.  I wish the front of my cabinet could look as nice as the back of yours.
jahilton2002
« Reply #6 on: May 14, 2012, 10:10:46 am »
thx man.... pic added
jmike
« Reply #7 on: May 14, 2012, 10:14:18 am »
How about you put those plasma plates in between the two bartops. I'm sure you've seen them around there's several builds with them around here. (see pic). Or depending on your theme maybe some artwork will do.
Good luck with your build. Can't wait to see some pics.
jahilton2002
« Reply #8 on: May 14, 2012, 10:20:29 am »
we were thinking carbon wrap with a perspex windows.... but plasma sound cool!
Louis Tully
« Reply #9 on: May 14, 2012, 10:31:03 am »
« Last Edit: February 12, 2015, 05:45:55 am by Louis Tully »
« Reply #10 on: May 14, 2012, 10:37:19 am »
Instead of having the tops angle down and back, what do they look like level across?
jahilton2002
« Reply #11 on: May 14, 2012, 10:39:25 am »
thats the bit that looks odd.... when its level...... i just want to place my pint on it!  ;D
Los Abrazos Rotos
« Reply #12 on: May 14, 2012, 10:59:56 am »
It just needs to be alot thinner, about half the size in the middle.. Otherwise its gonna just look like two bartops stuck together.
« Reply #13 on: May 14, 2012, 11:04:53 am »
I agree with it needing to be thinner. Might try having the tops of the backs of the monitors pretty much touching, and having a two-sided shared vertical marquee, so the top of the cab is only the thickness of the marquee (~1" or 2).
SteveR
  • Last login:February 14, 2023, 05:17:50 pm
« Reply #14 on: May 14, 2012, 12:08:09 pm »
Get a tubular piece of acrylic, cut in half, put on top, light it up!
JayB
  • Last login:January 25, 2013, 06:11:59 pm
« Reply #15 on: May 14, 2012, 12:09:38 pm »
I've always thought the Tron cab shape would make a good Vs Machine with screen and controls on front & back. What about a Tempest shape?
« Reply #16 on: May 14, 2012, 05:52:58 pm »
flat, lose the marquee area, and put a double sided marquee box on top, like a topper
jahilton2002
« Reply #17 on: May 14, 2012, 05:56:11 pm »
you guys have any examples of these?
« Reply #18 on: May 14, 2012, 06:00:26 pm »
Kind of like this, but imagine it lit, two sided, and back to back...
Unstupid
« Reply #19 on: May 15, 2012, 04:16:45 pm »
Keep em separate and just link em with a cable... that way you can go back to back, side by side, or at a 90deg angle from eachother.  Also if you want to ditch one screen all together and just use a gamepad or joystick and plug it into the connector port:
« Last Edit: May 15, 2012, 04:20:22 pm by Unstupid »
Unstupid
« Reply #20 on: May 15, 2012, 04:22:38 pm »
Besides..... How do you play back to back on a bar....  You vs the Bartender?
selfie
« Reply #21 on: May 15, 2012, 05:45:48 pm »
I like the idea but I think you would either need a dedicated table or legs of its own making it more of a cocktail than a bar top...
404
« Reply #22 on: May 15, 2012, 06:00:43 pm »
always wanted to see (and build) a small bartop candy cab.
jahilton2002
« Reply #23 on: May 16, 2012, 03:23:00 am »
sweet top work! i like that ALOT!
thx for the bainstorm guys  ;D
