Author Topic: Help with Original xbox Triggers Aracde Cabinet  (Read 3117 times)
DarkFulgore
  • Last login:November 25, 2013, 06:39:41 am
« on: May 14, 2012, 02:40:53 am »
Hello Please Forgive me if Posted in the wrong Place Bassicly wht iam Doing is Building and arcade Cabinet
and soldering the wires from a Original Microsoft Fat and to arcade parts i bought I got every thing solder correctly to every button except for the L,Triggers R,Triggers
can someone Please tell me How do i find the The Signal on the Triggers??? button so i can hook it up to a Button and Press it to control tht action or Show me were to solder exactly on the Controller
Heres the Diagram
http://www.slagcoin.com/joystick/pcb_diagrams/xbox_diagram2.jpg
johnm
  • Last login:September 27, 2025, 01:42:49 pm
Re: Help with Original xbox Triggers Aracde Cabinet
« Reply #1 on: May 14, 2012, 06:14:14 am »
Isn't it LT,RT and ground?
northerngames
  • Trade Count: (+18)
« Reply #2 on: May 14, 2012, 09:38:14 am »
center pin is signal on the triggers.
if you remove the triggers and solder to the controller pcb you add a 10k resistor to bypass the assembly to connect a arcade button to it.
looking at the link that pinout setup is horrible.
find another pcb pinout elsewhere as that one sucks and not very detailed at all.
like on the alternative side...OK so what it what the author forgot to add what they even were in that pic. you just guess solder them points and hope you guess them right I guess :laugh2:
« Last Edit: May 14, 2012, 09:45:56 am by northerngames »
rablack97
« Reply #3 on: May 14, 2012, 02:10:00 pm »
Here's the tut i followed.
Making an Arcade Stick Tutorial
This all you will need....there are 9 videos by DSEEMPLOYEE that will walk you through the whole thing..Your interest would be more part 8 and 9....for some reason he never got to part 10 but you will have enough to do what you need too.
« Last Edit: May 14, 2012, 02:16:20 pm by rablack97 »
