Author Topic: Can you powdercoat a wooden arcade cabinet?  (Read 2451 times)
Mark Thomas
  • Last login:August 16, 2014, 07:41:56 am
« on: May 12, 2012, 06:16:18 pm »
Hey folks I'm currently sanding down an old cabinet I'm working on. Once im all done I wanted to get a company to powdercoat it and get a really nice professional looking finish. Has anyone else here powder coated a wooden
Cabinet? And if so how did it come out?
Many thanks looking forward to hearing back from
You all.
jennifer
Re: Can you powdercoat a wooden arcade cabinet?
« Reply #1 on: May 12, 2012, 06:41:17 pm »
     Powder Coating wont work on wood, Its adhered the the surface [metal] with a positive/neg charge then baked.
There are a few other options available however, Paint being the most common.  Vinyl, a nice replaceable surface [sega did this], but over time time,
heat/cold contractions will loosen the edges.... And laminate, this on requires some foresite in the fact your T mouldings may not cover the edge if
you dont allow for the thickness, and its kind of spendy to do it right/nice.... Jennifer likes the paint method [spray, automotive] best.
ark_ader
  • I glow in the dark.
« Reply #2 on: May 12, 2012, 06:50:23 pm »
We have a furniture restorer/finisher that does what I think you are after.  He sprays thin emulsion on wood several times that it looks powder coated (as a comparison).
He did our dining table and chairs and they look totally cool, nice and smooth, brilliant white.  Good idea on the arcade cab.  I might go that route with the weecade #3
Looks a bit like this but thicker.
Mark Thomas
« Reply #3 on: May 12, 2012, 07:06:12 pm »
Thank you i wasn't aware you couldn't powder coat wood so I think the spray option sounds the best. I'm just after a nice jet black colour so it looks like a new cab again. How did you find the finish came out Jennifer and is there any special kind of preparation I need to do prior to getting it sprayed? So far I'm just sanding down with some paper.
jennifer
« Reply #4 on: May 12, 2012, 09:34:46 pm »
    I prefer stripper, thinner to neutralize, then a fine paper to clean it up.This way your not sanding waves across the surface.[ Or use a long block ]
A sealer, fix dings with bondo [?] spray a good sealer, Making sure that it compatable with the paint youll be using.... Most games that were black
were a flat/semi flat , gloss will show imperfections and always look dirty.
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
« Reply #5 on: May 12, 2012, 10:07:59 pm »
You can powdercoat wood.   I just read a few websites about it.   I wasn't aware that you could.
jennifer
« Reply #6 on: May 13, 2012, 12:55:36 pm »
       That is interesting, Seems the moisture content on mdf will conduct the charge....
Mark Thomas
« Reply #7 on: May 13, 2012, 01:30:52 pm »
So you can powder coat? I'm based on UK and got a reply from a powder coat company that i had emailed the other day basically saying that they can't do wood. Have you got some company links GregD?
Franco B
« Reply #8 on: May 13, 2012, 02:55:15 pm »
If I was to build another cab I would definitely use laminate for a hard wearing pro finish.
If it is something you would consider then there is some info in [this] thread which may be of use to you along with some UK suppliers.
Mark Thomas
« Reply #9 on: May 13, 2012, 06:03:46 pm »
Thanks for that info FancoB I would definitely laminate if the cab wasn't such an awkward shape. Once this cab is done I do have plans for an Xbox can so I will consider this option as I do think they look great when laminated by someone who knows what they are doing.
Iv heard back from another company who I had emailed they also stated that they can not powdercoat wood but said they could use 2 pack paint.
When I asked what this was they replied:
2 pack is car paint which give a good finish hard, this but  a long job as needs primer and wet flatin a few times to get a good finish. The wood keeps soaking in the paint in so a few coats are needed.
Have any of you guys used this stuff? It sounds very promising.
