Author Topic: MDF control panel - how thin can I get away with?  (Read 3225 times)
Los Abrazos Rotos
« on: May 08, 2012, 07:40:31 am »
Just wondering, whats the minimum thickness for an MDF control panel?  Would 9mm cut it?  The top of my CP measures 600x200mm.
« Last Edit: May 08, 2012, 07:49:46 am by Los Abrazos Rotos »
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Re: MDF control panel - how thin can I get away with?
« Reply #1 on: May 08, 2012, 08:13:18 am »
Too thin.  You need something that is going to be sturdy and 9mm comes out to .35 inches.  You need at least a half inch in thickness.
Los Abrazos Rotos
« Reply #2 on: May 08, 2012, 08:36:58 am »
Yeah, thats what I thought.. Back to the drawing board..
P-chan
  • Last login:April 13, 2022, 12:39:40 am
« Reply #3 on: May 08, 2012, 09:04:36 am »
I agree, 1/2" (12.7mm) minimum unless it was a bartop control panel....
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: May 08, 2012, 11:51:47 am »
Depends on the material and the structure.  The previous posters saying 1/2" is spot on, but if you really wanted to you could do some fancy engineering with stabilizers in key places adding more structure to it.  Then again we're talking more wood and metal on the inside of the CP and I'm not sure if you're doing this to save weight or size.
So yeah, 1/2" or greater please.
Los Abrazos Rotos
« Reply #5 on: May 08, 2012, 05:06:31 pm »
Thanks all
