Author Topic: Side Art Install 101  (Read 72818 times)
rikitiki
  • Last login:January 03, 2020, 01:17:35 pm
    • Custom Arcade Game Printing
« on: May 04, 2012, 04:15:36 pm »
I thought I share and post up a few of my sideart and kickplate art installation tutorials.
But first a couple of Sneak Peeks
Saving the Planet one Game at a time.
www.ThisOldGame.com
rikitiki
Re: Side Art Install 101
« Reply #1 on: May 04, 2012, 04:18:48 pm »
Full Sided Side Art Installation
A couple of things I forgot to cover in this tutorial
The squeege and slip cover which Ill be adding to my site soon and will posts some pics
as well. which was used mainly because some sideart is premasked and some is not.
I also did not cover cabinet prep. which is key to a good and perfect installation
These are installed all "DRY METHOD".
Wet method should only be done if the cab is WELL sealed
or when Applying Vinyl to Vinyl.
FAQs
"Wet Method"-Using a water mix or rapid tack BETWEEN the vinyl and the surface
not to be confused with using a soap/water on the vinyl surface like I did for vinyl siding. which was used only to reduce surface scratches and make the squegee slide alittle better.
"Dry Method"- Applied completly dry NO liquid used between the vinyl and its surface.
"Premask"- A lowtack material applied to the art side of a print to Both protect the print
and keep the vinyl from stretching during installation.
« Last Edit: May 04, 2012, 04:20:39 pm by rikitiki »
www.ThisOldGame.com
rikitiki
« Reply #2 on: May 04, 2012, 04:21:32 pm »
KickPlate install #1-W/premask
www.ThisOldGame.com
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
« Reply #3 on: May 04, 2012, 07:30:21 pm »
Excellent video tutorial !
  • Last login:July 24, 2025, 02:05:45 pm
« Reply #4 on: May 04, 2012, 09:43:53 pm »
 :notworthy:
rikitiki
« Reply #5 on: May 08, 2012, 05:59:21 pm »
Thanks! I finally finshed up another installing kickplate  art WITHOUT premask
I didnt plug the coin door on this one as I did with the previous one-Agent X
but would stil HIGHLY recomend pluging the coin door hole when applying vinyl/art to the front.
www.ThisOldGame.com
rikitiki
« Reply #6 on: June 22, 2012, 11:10:12 am »
So heres another one I recently did which was streamed from
the NW Pinball show in Seattle last weekend.
http://www.nwpinballshow.com/
There are very few pieces of side art that Id do via "WET" method.
DK is one and heres why.
The orginal coating on these machines is super slick and makes for a GREAT bond with the vinyl
almost too good. Making it harder to apply then it really needs to be.
Applying Donkey Kong sideart live
http://www.ustream.tv/recorded/23178310
The 2nd example Id recomend doing "Wet" is vinyl to vinyl for the same reason.
I should also note I dont give any speciffic placement for this art.
Mainly due to the fact there was allready sideart on the machine on the other side which was previoulsy done.
So I was simply matching that placement.
I do make reference to the fact that most original pics Ive seen including the flyer shows the "Donkey Kong" text
cenetering to the marquee and bezel retainer.
« Last Edit: June 22, 2012, 11:18:40 am by rikitiki »
www.ThisOldGame.com
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
« Reply #7 on: January 09, 2013, 04:09:54 pm »
[previous comments turned out to be incorrect and irrelevant]
Just want to say that this tutorial helped me out in a big way today -- thanks so much!   :notworthy:
« Last Edit: January 13, 2013, 12:15:30 am by Jumpman64 »
coral
  • Newbie
  • Last login:January 25, 2013, 01:20:42 am
« Reply #8 on: January 25, 2013, 01:20:14 am »
pdwire
  • Last login:September 26, 2013, 09:47:39 am
« Reply #9 on: April 10, 2013, 10:39:02 pm »
very helpful. .. going to be needing these soon.
blashyrk
  • Last login:May 14, 2017, 02:56:16 am
« Reply #10 on: May 26, 2013, 03:35:58 am »
Great video, It looks so easy when you do it :)
lowgunn
  • Last login:February 08, 2025, 02:33:10 pm
« Reply #11 on: June 13, 2013, 11:32:19 am »
What do you recommend on the material/brand to print the side art on.  I was thinking of doing this for a bartop kit I just bought. thanks in advance.
ranmoor
  • Last login:April 25, 2022, 05:55:45 am
« Reply #12 on: October 24, 2013, 01:32:13 pm »
Great video thanks  :applaud:
Zzap
  • Last login:September 06, 2021, 03:12:54 am
« Reply #13 on: November 27, 2013, 05:53:19 am »
Doh, the UStream video above from the expo seems to be missing now, is this around anywhere else?
cryoguns
  • Last login:September 26, 2014, 09:24:59 pm
« Reply #14 on: September 06, 2014, 10:14:46 am »
Just wanted to say "thanks" for the excellent tutorial!  I did a dry install on my Asteroids homage cabinet side art last night and was very please with how it turned out.  I was very apprehensive about not being able to fix it once started, but it really did work out well.
Thank you!
« Last Edit: September 06, 2014, 10:17:48 am by cryoguns »
graan
  • Last login:October 23, 2015, 02:39:41 am
« Reply #15 on: September 08, 2015, 09:01:19 am »
thanks 4 the info!
Qawsed11
  • Last login:September 23, 2017, 12:32:01 pm
  • Bartop maker and arcade restorer
« Reply #16 on: April 10, 2017, 11:53:56 am »
ZTylerDurden717
  • Last login:March 05, 2025, 08:15:15 am
« Reply #17 on: January 09, 2019, 11:36:37 am »
hey rikitiki,
I'm a first time builder approaching the artwork phase.  What's your take on folks who use the t-mold groove tuck-in method?
onesikcoupe
  • Last login:August 25, 2019, 08:24:33 pm
« Reply #18 on: August 25, 2019, 03:35:54 pm »
stigzler
    • Mago Arcade
« Reply #19 on: September 27, 2021, 07:06:32 pm »
Just to add to this, I made another sideart install vid here - thanks to rikitiki's original guide:
